06-27-2025, 10:35 AM
Dear Kincony
I use KC868-A8 with KCS v2.2.13[img]/local/images/tank0.png[/img]
MQTT is connected correctly
The sensor is configured for ADC1, via MQTT entity
State topic*
KC868_A8/2CBCBB658D44/STATE
Value template
{{ value_json.adc1.value }}
Ground Feeder Tank Level
29 minutes ago (the sensor does not update)
1,171 V
setting adc1
channel name: channel 1
unit: v
Custom value1 ( value when adc/dac is 0 ): 0
Custom value2 ( value when adc/dac is max range ): 5
Threshold ( Send mqtt when the change of sampling value is greater than it ): 1
if I switch any output, the MQTT message does come, but no MQTT message when the ADC value changes
State topic*
Value template
1,171 V
setting adc1
unit: v
