kc-868 AK
#11
I set this condition in KC-868 AK, the IF is time condition and THEN is protocol1+protocol2+protocol3+protocol4.
The protocols programed to tuggle Relay in H32B:
Protocol1—-> toggle relay 21
Protocol2—-> toggle relay 22
Protocol 3—-> toggle relay 23
Protocol 4——> toggle relay 24
But the problem i faced, is when i run the condition, it just operates the protocols in the first line, which is protocol1+protocol2.
Protocol 3 and 4 are not operating!!!
What i miss in the case?
post your 4 protocol content screen photo. how you define.
Protocols content photo:
between every THEN protocol action, add delay time, such as 1 second.
I added delay 1s like in the picture, and i see it’s working well.
Now the strange part is, without adding delay, i face the problem that i described in the beginning with H32B, and also A32pro.
But with A8v3 it works well(even without delay)!!!
Can you explain what is going here?
A8v3 use by ESP32S3, the CPU is faster than H32B's CPU.
but add delay is a stable way.
