Yesterday, 04:47 PM
I have a question about power supply for T128.
I'm using 24 V relays (Finder 40.52) connected to the Digital Outputs.
I am considering two power options:
Thank you in advance for your help.
regards,
Toper
- Two power supplies (this version works fine since 2 days):
- 12 V for the Kincony board (VCC),
- 24 V only for the outputs,
- common ground (GND) for both power supplies.
- One 24 V power supply:
- 24 V connected to VCC and to LO.
- Is it safe to connect the grounds (GND) of the 12 V and 24 V power supplies together?
- Does the manufacturer recommend using a common ground in this case?
- From thermal and reliability point of view, is it better to power everything with 24 V, or use 12 V for VCC and 24 V only for outputs?
regards,
Toper
