03-04-2026, 02:53 AM
The A18v2 is configured with MQTT, but the device's own monitor shows the MQTT status as disconnected, and Home Assistant does not recognize the device.
A18v2 MQTT Connected in Config but Shows "Disconnected" on Device Monitor – Not Detec
03-04-2026, 07:24 AM
check your mqtt broker. setting is correct.
i suggest you connect to another mqtt broker for a testing.
| 1 Guest(s) |
