CRC Errors with ESP Home & N10203060_KU_V20_260324SP
I updated the ARM firmware to N10203060_KU_V20_260324SP and then tried flashing the ESP Home config from https://www.kincony.com/forum/showthread.php?tid=9157
I'm now not getting any data and the following logs repeating over and over:
[20:07:41.184][W][modbus_controller:145]: Duplicate modbus command found: type=0x3 address=100 count=68
[20:07:41.189][W][modbus_controller:145]: Duplicate modbus command found: type=0x3 address=200 count=68
[20:07:41.189][W][modbus_controller:145]: Duplicate modbus command found: type=0x3 address=600 count=68
[20:07:41.412][W][modbus:063]: Stop waiting for response from 1 424ms after last send
[20:07:41.447][W][modbus:219]: CRC check failed 1ms after last send
[20:07:41.455][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 3ms after last send
[20:07:41.468][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:41.713][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:41.732][W][modbus:219]: CRC check failed 1ms after last send
[20:07:41.737][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:41.751][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:41.994][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:42.015][W][modbus:219]: CRC check failed 2ms after last send
[20:07:42.021][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 5ms after last send
[20:07:42.036][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 23ms after last send
[20:07:42.402][W][modbus:063]: Stop waiting for response from 1 389ms after last send
[20:07:42.423][W][modbus:219]: CRC check failed 1ms after last send
[20:07:42.429][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:42.443][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:42.684][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:42.705][W][modbus:219]: CRC check failed 1ms after last send
[20:07:42.710][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:42.726][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:42.969][W][modbus:063]: Stop waiting for response from 1 266ms after last send
[20:07:43.007][W][modbus:219]: CRC check failed 1ms after last send
[20:07:43.012][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 3ms after last send
[20:07:43.026][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:43.407][W][modbus:063]: Stop waiting for response from 1 401ms after last send
[20:07:43.426][W][modbus:219]: CRC check failed 1ms after last send
[20:07:43.432][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:43.445][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:43.690][W][modbus:063]: Stop waiting for response from 1 265ms after last send
[20:07:43.710][W][modbus:219]: CRC check failed 1ms after last send
[20:07:43.715][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:43.730][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:43.975][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:43.996][W][modbus:219]: CRC check failed 1ms after last send
[20:07:44.001][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:44.012][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:44.402][W][modbus:063]: Stop waiting for response from 1 411ms after last send
[20:07:44.422][W][modbus:219]: CRC check failed 1ms after last send
[20:07:44.428][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:44.441][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:44.687][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:44.722][W][modbus:219]: CRC check failed 1ms after last send
[20:07:44.728][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 3ms after last send
[20:07:44.741][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send
[20:07:44.984][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:45.004][W][modbus:219]: CRC check failed 1ms after last send
[20:07:45.013][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send
[20:07:45.024][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send
[20:07:45.407][W][modbus:063]: Stop waiting for response from 1 403ms after last send
[20:07:45.425][W][modbus:219]: CRC check failed 1ms after last send
[20:07:45.430][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send
[20:07:45.444][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send
[20:07:45.687][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:45.718][W][modbus:219]: CRC check failed 1ms after last send
[20:07:45.718][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send
[20:07:45.727][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send
[20:07:45.971][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:45.992][W][modbus:219]: CRC check failed 1ms after last send
[20:07:45.998][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send
[20:07:46.011][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send
There are no other changes to the system, just completed that ARM firmware update and flashed the example ESP Home config
you can test with KCS v3 firmware firstly. here is download link: https://www.kincony.com/forum/showthread.php?tid=9334
Turns out I just needed to power-cycle the N60 after the updated ESP Home flash.
yes
