Yesterday, 04:15 AM
Here is sample, KinCony F24 connect with one TS RS485 sensor, you can connect with multi TS sensors.
for example:
set F24 RS485 protocol = "Modbus-RTU", baud rate= 9600bps. the RS485 address should be different with TS' RS485 address.
TS sensor default address is 1, so set in "SENSOR" webpage:
Then it will work in monitor webpage:
for example:
