Request for 230VAC LEDs / Downlight
I'm currently building my house and i'm planning to be able to adjust the lighting in all my rooms (30 zones).
I came across your DIN rail modules, which I think are perfect. Great job!!
However, a have a quick question: how can I dim 230VAC dimmable LED spotlights / downlight from 0% to 100% without any flickering and which the real 0% (using a triac?) ?
Best regards
Benoit
sure, you can chose DM series product + SSR driver.
here is SSR driver: https://shop.kincony.com/products/0-10v-...s=e&_v=1.0
Thanks for your reply ! Smile
Does this SSR have phase cutoff at zero crossing?
yes.
Thanks Smile Smile
Finally, do you have a recommendation for a low-profile dimmable LED ceiling spotlight on AliExpress that operates at 230v and is compatible with your SSR?
you can buy big company's product, it's ok.
