Does KCS v3 firmware for KC868-H16S3 support a 'delay' parameter in MQTT SET commands
Hello admin
I am using a B16 smart relay controller with your KCS v3 firmware. I am integrating it with Home Assistant to control a Somfy WT roller shutter.
For this application, I need to send an MQTT command to activate a relay for a specific duration (e.g., "turn on output1 for 3 seconds, then turn it off automatically").
I've reviewed the KCS v3 MQTT protocol document (specifically, section 1 about setting ON/OFF of a digital output channel). It shows how to turn relays ON or OFF:
{"outputX":{"value":true}}
{"outputX":{"value":false}}
My question is: Does KCS v3 firmware support an additional parameter like
{"delay": milliseconds}
within the MQTT SET command, similar to how some other firmwares allow?
For example, would a command like this work to turn on
output1
for 3 seconds and then automatically turn it off?
{"output1":{"value":true}},{"delay":3000}
If not, what is the recommended method for implementing time-based relay control (e.g., activating a relay for a specific duration) when integrating with Home Assistant using KCS v3 firmware?
Thank you for your assistance.
KCS mqtt protocol not support delay time. you can set the auto off time in KCS webpage -- OUTPUT, set the OUTPUT work as a "delay" mode. so that every time, when relay is ON, will auto off after x seconds.
