function: Use KinCony G1 module to transparently transmit AT commands of SIM7600 4G module to gpio13 and gpio14 of esp23-s3. So that KinCony Controller can connect with extend G1 4G module by KCS v3 firmware.
BIN file download to ESP32-S3 directly:
7-GSM-Test-extend-pins.ino.merged.zip (Size: 184.13 KB / Downloads: 498)
#include <HardwareSerial.h>
// Define hardware serial ports
HardwareSerial SimSerial(1); // Use hardware serial port 1 (GPIO9 and GPIO10)
HardwareSerial ExtendSerial(2); // Use hardware serial port 2 (GPIO13 and GPIO14)
// Initialize the extended serial port (hardware serial port 2)
ExtendSerial.begin(115200, SERIAL_8N1, 13, 14); // RX=GPIO13, TX=GPIO14
while (!ExtendSerial) {
; // Wait for the extended serial port to connect
// Initialize the SIM7600 serial port (hardware serial port 1)
SimSerial.begin(115200, SERIAL_8N1, 9, 10); // RX=GPIO9, TX=GPIO10
// If data is received from the extended serial port, forward it to the SIM7600 module
if (ExtendSerial.available()) {
while (ExtendSerial.available()) {
char data = ExtendSerial.read();
SimSerial.write(data);
// If data is received from the SIM7600 module, forward it to the extended serial port
if (SimSerial.available()) {
while (SimSerial.available()) {
char data = SimSerial.read();
ExtendSerial.write(data);
