KinCony TS Tiny SHT30 Temperature And Humidity Sensor released
KinCony TS (Tiny Sensor) made by SHT30 temperature and humidity sensor inside.
[Image: TS-1.jpg][Image: TS-5.jpg]
product size: 20mm*18mm
power supply: DC 9-36V
temperature: -40℃-- +125℃
humidity: 0--100% RH
temperature accuracy: 0.1℃
humidity accuracy: 0.1% RH
communication: RS485
RS485 baud rate: 9600/14400/19200/38400/56000/57600/115200 bps
RS485 address: 1--255 editable
LED D3: power LED
LED D4: running LED (blink with running)
Jumper: RS485 Terminating resistor jumper (make sure last RS485 slave device enable it)
[Image: TS-8.jpg]
You can read temperature and humidity by PC software via RS485 USB adapter.
you can set KinCony TS by different address and Baud.
[Image: ts-pc-1.png]
[Image: ts-pc-2.png]
What is the difference this, and boxed ( https://shop.kincony.com/products/rs485-...e-by-sht30 ) sensor? Price is 5x.
make the sensor smaller , cost will be high. it's 4 layer PCB version, more stable.
