I have had the F16 for awhile now but over the past few weeks, the relays suddenly stopped working. I can control the relay functions in HA and can hear the click sound of the relay but the lights remained on (the relays are connected to light circuit). When I touch the board it is very hot.Is this normal? How to fix this issue?
you can disconnect relay output wire with load. use multi meter to relay5, when turn on/off, then COM and NO whether is CLOSE and OPEN. just test without load.
Yesterday, 11:19 AM (This post was last modified: Yesterday, 11:23 AM by autolifetech.)
Ok i think i found my issue. Relay spoil because of voltage. i recently changed from 12v psu to 24V psu because my 12v psu spoil but forgot reay is default 12v. will upgrade to 24v
Ok i think i found my issue. Relay spoil because of voltage. i recently changed from 12v psu to 24V psu because my 12v psu spoil but forgot relay is default 12v. will upgrade to OMRON G2R 1F 24v
