Loxone KC868-A8
Any special firmware for Loxone integration with the KC868-A8 board?
here is config ESPHome component for Loxone: https://github.com/hzkincony/esphome-loxone
here is video tour how to do : https://www.youtube.com/watch?v=yj-tDb4gRa0
Hello
Integration with Loxone?
Please could you send the link or explain how do it?
Best regards
I'm watching the ESPHome integration with Loxone, thanks
just do as video , the Loxone component made for ESPHome use UDP command.
Is better and easy if works with your software...with KC v2.2.2
The relay output I can control...but not the inputs and sensors
Do you have a template for it?
Best regards
With the UDP Monitor I find to detect the sensor and state...
But I can find the DS18B20 sensor in UDP
How I can read the sensor please?
maybe in furture, we will update KCS firmware to support Loxone by UDP.
Now works with Loxone by UDP (inputs and outputs), But I can't read the sensor DS18B20
I can read in the KCS Firmware
How I can read the sensor by UDP? or Modbus? or TCP?
yes, Loxone component for ESPHome not added the sensor, maybe in furutre can add that.
now you can read sensor by HTTP command, Loxone support integrate by HTTP.
How I can read by Http?
I'm checking the manual and don't find
Please could you give me the link http
Thanks
I find it
Activate HTTP Server - secret: abcd
And then link:
http://192.168.1.133/ctrl.cgi?cmd=get_se...ecret=abcd
Now I will TRY integrate in Loxone
