  • 1 Vote(s) - 4 Average
KC868-H32B V4.37 new firmware update
[Image: kc868-h32b_pix550.jpg]
improvement:
set every relay output momentary time separately.
download the ZIP file , unzip update the bin file for KC868-H32B relay controller by USB-RS232 cable.
.zip   Relay32_V437_210907.zip (Size: 46.05 KB / Downloads: 1,025)
firmware update tool download: https://www.kincony.com/download/KC868-C...loader.zip
Why I cannot set more than 6 relays momentary timers?
If I set more than 6 relay timers, all timers will be unselected when I save
Is that normal?
can you take a video?
Hi, I have updated to this version, but after reset and restart of the controller the relay Nr. 3 is allways on.
It is on when I unplug it and then replug it, when I save any setting on the web config(after restart) the reley 3 turns on.
I can turn it off with a momentary switch, but after another restart the relay is again on.
I need this version, because of the multiple timers.
Thank you.
maybe you have turn on the relay3, and use the relay state remember function.so every time you power on will recovery relay state as last time.
before the restart of controller all relays are off.
After restart relay 3 turns on.
This was also after I uploaded the new firmware.
do you means:
step1: turn ALL OFF relays.
step2: power off->on of controller.
step2: when startup, relay3 will be on automatic?
Yes, this is what is happening.
Is there any news for my problem? If relays are off before the restart of controller, I need it to be off. I am going to the client on friday.
Thank you.
I have done firmware updates, but seem nothing has changed. I have follow firmware updates guide from, https://www.youtube.com/watch?v=LLIJe9VTVq8
After firmware updates:
0 Software Version: 4.13.26 (2020-03-20 11:00 2M)
