Threads: 0
Why I cannot set more than 6 relays momentary timers?
If I set more than 6 relay timers, all timers will be unselected when I save
Is that normal?
Threads: 1
Hi, I have updated to this version, but after reset and restart of the controller the relay Nr. 3 is allways on.
It is on when I unplug it and then replug it, when I save any setting on the web config(after restart) the reley 3 turns on.
I can turn it off with a momentary switch, but after another restart the relay is again on.
I need this version, because of the multiple timers.
Thank you.
Threads: 1,558
maybe you have turn on the relay3, and use the relay state remember function.so every time you power on will recovery relay state as last time.
Threads: 1
before the restart of controller all relays are off.
After restart relay 3 turns on.
This was also after I uploaded the new firmware.
Threads: 1,558
do you means:
step1: turn ALL OFF relays.
step2: power off->on of controller.
step2: when startup, relay3 will be on automatic?
Threads: 1
Yes, this is what is happening.
Threads: 1
Is there any news for my problem? If relays are off before the restart of controller, I need it to be off. I am going to the client on friday.
Thank you.
