05-06-2024, 01:35 AM
let your own RS485 temperature and humidity sensor can work with Tuya app, so that can remote monitor sensor data and make AUTOMATION by Tuya app via internet.
arduino source code donwload:
Tuya_AdapterV2_RS485_Temper_Hum.zip (Size: 1.98 KB / Downloads: 938)
#include <ModbusMaster.h>
#include <Arduino.h>
#include <TuyaWifi.h>
#include "HardwareSerial.h"
//---------RS485 setting
#define DEBUG 1
#define SERIAL_BAUD 9600
#define RX_PIN 32
#define TX_PIN 33
#define SERIAL_NUM 2
#define SLAVE_ADDR 1
#define READ_ADDR 0
#define READ_NUM 2
HardwareSerial My485Serial(SERIAL_NUM);
ModbusMaster node;
uint16_t rcv_buf[READ_NUM] = {0};
float get_value[2] = {0.0};
/* Current device DP values */
int temperature = 0;
int humidity = 0;
static void ReadInputRegs(void)
uint8_t result = node.readInputRegisters(READ_ADDR, READ_NUM);
if (result == node.ku8MBSuccess) {//if communicate successful then
#if DEBUG
Serial1.print("Result:");
#endif
for (uint8_t j = 0; j < READ_NUM; j++)
rcv_buf[j] = node.getResponseBuffer(j);
#if 0 ///just for debug.
Serial1.print(" 0x");
Serial1.print( rcv_buf[j], HEX );//display data in hex.
#endif
get_value[0] = rcv_buf[0]/10;///huminity
get_value[1] = rcv_buf[1]/10;///temperature
temperature = rcv_buf[0];
humidity = get_value[1];
#if DEBUG
Serial1.print("humi.<");
Serial1.print(get_value[1]);
Serial1.print("%>");
Serial1.print(" temp.<");
Serial1.print(get_value[0]);
Serial1.println("°c>");
#endif
//delay(300);
else
node.clearResponseBuffer();
//---RS485 setting end----
TuyaWifi my_device;
/* Current LED status */
unsigned char led_state = 0;
int key_pin = 25;
/* Data point define */
#define DPID_TEMP_CURRENT 1
#define DPID_HUMIDITY_CURRENT 2
#define LED_WiFi 26
//#define LED_User 33
* dp type(TuyaDefs.h) : DP_TYPE_RAW, DP_TYPE_BOOL, DP_TYPE_VALUE, DP_TYPE_STRING, DP_TYPE_ENUM, DP_TYPE_BITMAP
unsigned char dp_array[][2] =
{DPID_TEMP_CURRENT, DP_TYPE_VALUE},
{DPID_HUMIDITY_CURRENT, DP_TYPE_VALUE},
unsigned char pid[] = {"dpyditdgaadmqw8m"};
/* last time */
unsigned long last_time = 0;
void setup()
My485Serial.begin(SERIAL_BAUD, SERIAL_8N1, RX_PIN, TX_PIN); //RS485 serial port
node.begin(SLAVE_ADDR,My485Serial);
Serial.begin(9600,SERIAL_8N1,22,19); //Tuya module serial port
Serial1.begin(115200,SERIAL_8N1,3,1); //USB serial port
// Serial with tuyawifi
pinMode(LED_WiFi, OUTPUT);
digitalWrite(LED_WiFi, LOW);
/* pinMode(LED_User, OUTPUT);
digitalWrite(LED_User, LOW);*/
//Initialize networking keys.
my_device.init(pid, mcu_ver);
my_device.set_dp_cmd_total(dp_array, 2);
//delay(300);
last_time = millis();
void loop()
ReadInputRegs(); // read RS485 sensor
my_device.uart_service();
//Enter the connection network mode when Pin7 is pressed.
delay(80);
if (led_state == LOW) {
led_state = HIGH;
} else {
led_state = LOW;
digitalWrite(LED_WiFi, led_state);
/* report the temperature and humidity */
if ((my_device.mcu_get_wifi_work_state() == WIFI_CONNECTED) || (my_device.mcu_get_wifi_work_state() == WIFI_CONN_CLOUD)) {
my_device.mcu_dp_update(DPID_TEMP_CURRENT, temperature, 1);
my_device.mcu_dp_update(DPID_HUMIDITY_CURRENT, humidity, 1);
delay(1000);
* @param {unsigned char} dpid
* @return {unsigned char}
/* all DP only report */
return TY_SUCCESS;
* @param {*}
* @return {*}
void dp_update_all(void)
