Threads: 13
I tried but it didn't work...what is the associated yaml file?
it still seems that the card can't connect to the network
Threads: 1,389
do you MUST want to use ethernet?
when you bought M16v2 from? tell us your order number, we will check.
Threads: 13
I would like to use ethernet, I bought the card with poe module on purpose. I bought it on 26-01-2025, with Express checkout.
the email is athxp(@)tiscali(dot) it
Threads: 1,389
send your order number and store link to whatsapp number: +86-15381188302 we check for you.
Threads: 1,389
telegram: +86-15381188302
Threads: 13
I contacted via telegram but I had no response....is the contact active?
Threads: 1,389
05-06-2025, 12:35 AM
(This post was last modified: 05-06-2025, 12:35 AM by admin.)
because the same question you send to whatsapp and telegram repeatly. by one chat way is enough.
Threads: 0
06-21-2025, 11:02 AM
(This post was last modified: 06-21-2025, 11:24 AM by The_Muffin_Man.)
Hi, I have just bought the KC868-M16-V2.1 and I'm having the same issue display is working with temp and humidity reading but I have no Ethernet working.
I have tried the m16v2.factory.zip and the yaml example supplied in this thread with no luck.
If i use the yaml example for the KC868-M16 the Ethernet works fine but I have no display, temp or humidity
I had the same issue with no Ethernet but I was able to resolve it by using esptool to erase and flash the m16v2.factory.bin
esptool -p /dev/ttyUSB0 erase_flash
esptool --chip esp32 -p /dev/ttyUSB0 -b 115200 write_flash 0x0 m16v2.factory.bin
Now Ethenet works and so does the display.
