KC868-A16 ethernet work with home assistant by ESPHome configure
#11
ok, good.
Привет! Не получается подключить к Home Assistant. Что я делаю не так?
Hi! I can't connect to the Home Assistant. What am I doing wrong?
.txt   logs_kc-868-otoplenie_run.txt (Size: 173.62 KB / Downloads: 312)
.txt   дописал 8 выходов.txt (Size: 2.19 KB / Downloads: 250)
if you use our yaml file directly, whether work well?
(01-11-2026, 11:18 AM)admin Wrote: if you use our yaml file directly, whether work well?
when using your original YAML file, it also doesn't work.
I changed the beginning of the yaml file, there was this error
.txt   logs_kc-868-a16_run.txt (Size: 89.6 KB / Downloads: 348)
updated yaml file for newest ESPHome.
  friendly_name: a16
    type: arduino
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk:
    pin: GPIO17
    mode: CLK_OUT
  phy_addr: 0
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      # Use pin number 0
      # One of INPUT or OUTPUT
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_2
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_in_1
      # Use pin number 0
      inverted: false
      pcf8574: pcf8574_hub_in_2
      # Use pin number 0
      inverted: false
  - platform: dht
    pin: 32
    temperature:
    humidity:
      name: "Living Room Humidity"
    update_interval: 60s
web_server:
  port: 80
yaml file download:
.txt   ESPHome_A16.txt (Size: 1.8 KB / Downloads: 340)
(01-11-2026, 12:53 PM)admin Wrote: updated yaml file for newest ESPHome.
  friendly_name: a16
    type: arduino
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk:
    pin: GPIO17
    mode: CLK_OUT
  phy_addr: 0
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      # Use pin number 0
      inverted: false
      # Use pin number 0
      inverted: false
  - platform: dht
    pin: 32
    temperature:
    humidity:
web_server:
  port: 80
yaml file download:
Hi! I used the updated yaml file. Mistake!
.txt   logs_kc868otopl_run (1).txt (Size: 154.72 KB / Downloads: 307)
where have problem? it already compile finished.
(01-17-2026, 12:03 PM)admin Wrote: where have problem? it already compile finished.
there are no devices or objects
tested with this new yaml, it can work directly.
  friendly_name: a16
    type: arduino
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk:
    pin: GPIO17
    mode: CLK_OUT
  phy_addr: 0
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
      mode: OUTPUT
      inverted: false
      mode: OUTPUT
      inverted: false
      mode: OUTPUT
      inverted: false
      mode: OUTPUT
      inverted: false
      number: 4
      mode: OUTPUT
      inverted: false
      number: 5
      mode: OUTPUT
      inverted: false
      number: 6
      mode: OUTPUT
      inverted: false
      number: 7
      mode: OUTPUT
      inverted: false
      mode: OUTPUT
      inverted: false
      mode: OUTPUT
      inverted: false
      mode: OUTPUT
      inverted: false
      mode: OUTPUT
      inverted: false
      number: 4
      mode: OUTPUT
      inverted: false
      number: 5
      mode: OUTPUT
      inverted: false
      number: 6
      mode: OUTPUT
      inverted: false
      number: 7
      mode: OUTPUT
      inverted: false
      number: 4
      number: 5
      number: 6
      number: 7
      number: 4
      number: 5
      number: 6
      number: 7
web_server:
  port: 80
yaml file:
.txt   ESPHome_A16.txt (Size: 5.37 KB / Downloads: 399)
Hello admin! I figured out everything with the home assistant and connected it, but there is a problem. Sometimes output 14-15 turns on spontaneously and output 16 logically works with it. what could be the problem?
.txt   Готовая 19.01.2026.txt (Size: 8.31 KB / Downloads: 320)
