Can't connect using KCS firmware
I just purchased KC868-A6V3 Board.
On connecting the unit I tried connecting using wifi hotspot.
I did not find the hotspot I was expecting instead a "Hidden network" appeared in Wifi network list.
I was unable to connect to this
I thought that perhaps unit had shipped unconfigured as I purchased from Aliexpress.
I then tried flashing using KCS_A6V3__v3.19.0 firmware but got the same result.
Firmware tool indicated successful installation.
I then tried setting up using ESPhome in HA using your supplied YAML file and that worked OK , unit comes online  , relays are able to be used.
I tried again using KCS firmware but still same result and Hidden network appeared again in Wifi list.
I tried connecting using SSID of ALR-0070077FE024 and passkey supplied in ESPhome YAML file which got me to the message "unable to connect to this network"
I then went back to ESPhome configuration and it works again and appears online , relays work
This proves that the hardware works but I really want to use the Lora functionality to control some water controllers I have.
Also the LCD display has never displayed anything , - why
Any assistance you can supply is much appreciated
after you downloaded KCS v3 firmware, whether re power on the board?
(02-15-2026, 11:41 AM)admin Wrote: after you downloaded KCS v3 firmware, whether re power on the board?
Yes I did power off and on
I should have mentioned I get the following output from the serial port when KCS firmware installed.
I followed your installation instructions exactly.
I got the result shown in attached picture
I get this info from serial
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
invalid header: 0x6564616f
ets Jul 29 2019 12:21:46
Regards
take photo of full screen.
OK , just flashed again and get this result
I powered board off then on , In wifi settings I get "Hidden Network" and for a short while also "OnlyLans" which disappeared soon after
Further info. The Hidden Network and OnlyLans networks are not coming from the KC868 as they appear even when KC868 not switched on. My apologies I thought they were .
do you have chosed "ESP32S3" chip type?
take a photo of your PCB board.
Here are pictures. I have always used ESP32 chip type when flashing as that is what your instructions say
this is KC868-A6 board, NOT KC868-A6v3 board. the A6v3 board is blue color.
you should download KCS v2 firmware for your board. here is link: https://www.kincony.com/forum/showthread.php?tid=8795
