03-03-2026, 10:41 AM
There's no way to change the speed and port using Modbus. Please fix this or send me a firmware update with port 4 instead of the default 1. Thank you.
N10 port modbus
03-03-2026, 12:49 PM
RS485 use by modbus. what's your means?
03-03-2026, 01:28 PM
03-04-2026, 02:03 AM
RS485 is connected with ARM CPU pin, it fixed.
03-04-2026, 07:31 AM
why can't connect with multi N10? just download KCS v3 firmware, set the RS485 address for N10. then you can read by modbus. You can set different address for different N10.
03-04-2026, 10:49 PM
(03-04-2026, 07:31 AM)admin Wrote: why can't connect with multi N10? just download KCS v3 firmware, set the RS485 address for N10. then you can read by modbus. You can set different address for different N10. It costs KCS v3 firmware, which was written in the first post. There is no modbus control, look carefully for yourself! There is no such thing on the menu!
03-05-2026, 12:39 AM
You can use PC software, connect to Nx board by USB-RS485 adapter . So that can set for RS485 modbus address.
03-05-2026, 04:02 AM
03-05-2026, 07:33 AM
i suggest you wait for some days, we will release new ARM CPU firmware and PC software soon.
it will support 0.001kwh for unit.
