04-17-2026, 06:04 PM
Hi, hopefully someone can help where I'm having issues calibrating the m16v2 energy meter in the UK which is on 240v with 1 phase.
Currently I am only focusing on CT_15 which is the Grid, I have a Shelly EM using a 120a1v CT clamp which is on the same line as CT_15.
When attempting to calibrate with 2 resistive loads (not at the same time) it just simply falls out of line when then seeing real world usage after, for example I had turned on a 3000w kettle, the Shelly shown the correct load so I then calibrated the figures as recommended in Kincony code, then I tried a 1500w electric heater but instead of the load being somewhat close to the expected reading, it was instead 1900w.
Additionally, when on normal realworld load where the house has typical appliances on which would bring it to about 300w on the Shelly, the m16 instead reports that its 600w.
I can confirm that I have connected the m16 to the consumer unit as recommended so then it shows what the voltage is, which I can confirm is accurate when compared against the Shelly which reports basically the exact same voltage.
All clamps are 1v, and are shown in order of what they're used for along with the amp:
I've attached code currently being used.
- 1 - Shower - 50a
- 2 - Cooker - 50a
- 3 - Kithcen Ring - 30a
- 4 - Dish Washer - 30a
- 5 - Washing Machine - 20a
- 6 - Tumble Dryer - 30a
- 7 - Reserved
- 8 - Reserved
- 9 - Fridge - 20a
- 10 - Reserved
- 11 - Reserved
- 12 - Reserved
- 13 - Reserved
- 14 - General Ring - 30a
- 15 - Grid - 100a
- 16 - Reserved
type: arduino
ota:
- platform: esphome
external_components:
- source:
type: git
url: https://github.com/hzkincony/esphome-zmpt101b
ref: v2.1.0
encryption:
key: "D69bY/GXlmjYkovak6WIhgmbOH8vwyqvMxIHBriYoaY="
# Wifi Configuration
wifi:
ssid: !secret wifi_ssid
fast_connect: true
sda: 4
scl: 5
cd74hc4067:
- id: cd74hc4067_1
pin_s0: 32
pin_s1: 33
pin_s2: 13
pin_s3: 16
web_server:
port: 80
font:
- file: "gfonts://Roboto"
- platform: adc
pin: 34
update_interval: never
attenuation: 12db
- platform: adc
pin: 36
attenuation: 12db
- platform: adc
pin: 39
attenuation: 12db
- platform: zmpt101b
# name: "m16--AI zmpt 34"
sensor: adc34
sensitivity: 538
- platform: adc
pin: 35
attenuation: 12db
- platform: cd74hc4067
sensor: adc35
update_interval: 5s
sensor: adc35
update_interval: 5s
sensor: adc35
update_interval: 5s
sensor: adc35
update_interval: 5s
number: 4
sensor: adc35
update_interval: 5s
number: 5
sensor: adc35
update_interval: 5s
number: 8
sensor: adc35
update_interval: 5s
number: 13
sensor: adc35
update_interval: 5s
number: 14
sensor: adc35
update_interval: 5s
- platform: ct_clamp
sensor: ai1
name: "CT 1 Current"
update_interval: 5s
filters:
# 50a 1v CT clamp on a known 8.5kw shower
- calibrate_linear:
- 0 -> 0
- 1 -> 50
- lambda: if(x < 0.2) return 0; else return x;
- platform: template
name: "CT 1 Power"
lambda: return id(CT_1_Current).state * id(voltage_1).state;
device_class: power
unit_of_measurement: "W"
update_interval: 5s
sensor: ai2
name: "CT 2 Current"
update_interval: 5s
filters:
# 50a 1v CT clamp on a cooker
- calibrate_linear:
- 0 -> 0
- 1 -> 50
- lambda: if(x < 0.25) return 0; else return x;
name: "CT 2 Power"
lambda: return id(CT_2_Current).state * id(voltage_1).state;
device_class: power
update_interval: 5s
sensor: ai3
name: "CT 3 Current"
update_interval: 5s
filters:
- calibrate_linear:
- 0 -> 0
- 8.24 -> 11.68
- lambda: if(x < 0.05) return 0; else return x;
name: "CT 3 Power"
lambda: return id(CT_3_Current).state * id(voltage_1).state;
device_class: power
update_interval: 5s
sensor: ai4
name: "CT 4 Current"
update_interval: 5s
filters:
# 30a 1v CT clamp - Dish Washer
- calibrate_linear:
- 0 -> 0
- 1 -> 30
- lambda: if(x < 0.1) return 0; else return x;
name: "CT 4 Power"
lambda: return id(CT_4_Current).state * id(voltage_1).state;
device_class: power
update_interval: 5s
sensor: ai5
name: "CT 5 Current"
update_interval: 5s
filters:
# 20a 1v CT clamp - washing machine
- calibrate_linear:
- 0 -> 0
- 1 -> 20
name: "CT 5 Power"
lambda: return id(CT_5_Current).state * id(voltage_1).state;
device_class: power
update_interval: 5s
sensor: ai6
name: "CT 6 Current"
update_interval: 5s
filters:
# 30a 1v CT clamp - tumble dryer
- calibrate_linear:
- 0 -> 0
- 1 -> 30
name: "CT 6 Power"
lambda: return id(CT_6_Current).state * id(voltage_1).state;
device_class: power
update_interval: 5s
sensor: ai9
name: "CT 9 Current"
update_interval: 5s
filters:
# 20a 1v CT clamp - Fridge
- calibrate_linear:
- 0 -> 0
- 1 -> 20
name: "CT 9 Power"
lambda: return id(CT_9_Current).state * id(voltage_1).state;
device_class: power
update_interval: 5s
sensor: ai14
name: "CT 14 Current"
update_interval: 5s
filters:
# 30a 1v CT clamp - General ring
- calibrate_linear:
- 0 -> 0
- 1 -> 30
name: "CT 14 Power"
lambda: return id(CT_14_Current).state * id(voltage_1).state;
device_class: power
update_interval: 5s
sensor: ai15
name: "CT 15 Current"
update_interval: 5s
filters:
- calibrate_linear:
method: exact
datapoints:
- 0.0 -> 0.0
- 0.016 -> 1.62
- 4.85 -> 5.88
- 8.26 -> 13.58
name: "CT 15 Power"
lambda: return id(CT_15_Current).state * id(voltage_1).state;
device_class: power
update_interval: 5s
- platform: total_daily_energy
name: "CT 15 Total Daily Energy"
power_id: CT_15_Power
unit_of_measurement: kWh
accuracy_decimals: 3
device_class: energy
state_class: total_increasing
filters:
- multiply: 0.001
time:
- platform: sntp
