N30 no Energy (kWh)
I have buy 3 N30 to monitor energy.
I use latest software
Board Model
N30
Software Version
v3.24.5
Build Date
Apr 29 2026 05:26:42
Serial Number
D0CF13020568
I connect 1,2,3 voltage and connect 3 phase conditionner to CH2
Energy Monitor 1
CH 2
Energy Monitor 2
CH 2
Energy Monitor 3
CH 2
and other 1 pahse load to other ports.
How make to get Energy (kWh)?
download this newest firmware for ARM CPU by USB-RS485 adapter.
https://www.kincony.com/forum/showthread.php?tid=9171
I had something similar with the N30 board I bought in April this year and noticed that I had to power-off the board and power-on to force the board to use the new factro settings if you changed them.
Did a lot of changes to the factors because I am using CT 1000:1 (efectively the appeared to need a factor of 2.1 to get close to a real Power value.
Only after unlugigng the board and restarting it suddenly was close to what I configured.
We strongly recommend using a 2000:1 CT sensor, preferably a KinCony CT sensor, which requires no complicated configuration.
I have update software with rs485. i see power. thank you.
I update another device. (because i dont have access to device on photos)
Another device i see such data.
Is this correct values?
Should i change power setting on page settings?
I use clamps like on your site https://shop.kincony.com/products/25a-cu...s=e&_v=1.0
DL-CT03CL2.0 2000/1
if you use kincony's CT sensor, you not need to change setting. all setting are "1"
(Yesterday, 12:49 AM)admin Wrote: if you use kincony's CT sensor, you not need to change setting. all setting are "1"
This is another CT like yours.
So the same 1 should be at all inputs?
"1" is usually used. sometime, only need change a little when needed.
Most of the time, you only need to set it to 1.
