N60/N30/N20/N10 PC software for RS485 modbus connection
connect PC to N60 by USB-RS485 adapter.
pc software download:
.zip   N60_APP.zip (Size: 1.66 MB / Downloads: 680)
new version have adjust the font size, so that can monitor by all by one screen.
PC software download:
.zip   N60_APPV1.0.25.0831.zip (Size: 1.66 MB / Downloads: 505)
new APPV1.0.25.1231 added clear energy data function.
added Set coefficient function.
.zip   N60_APPV1.0.25.1231.zip (Size: 1.66 MB / Downloads: 364)
new APPV1.0.26.0306 support 0.001kwh precision.
.zip   N60_APPV1.0.26.0306.zip (Size: 1.65 MB / Downloads: 274)
when click clear energy data button, suggest turn off your load or disconnect with CT sensor.
note: make sure your ARM CPU firmware >= N102030_KU_V20_260305SP, here is ARM CPU download link:
https://www.kincony.com/forum/showthread.php?tid=9107
When I try to use this app, I can't select a COM port. The "Port" drop-down only shows the text "uiComboBox1". Even if I type in "COM4", the port won't open.
do you have connected USB-RS485 adapter on PC?
(09-25-2026, 12:28 PM)admin Wrote: do you have connected USB-RS485 adapter on PC?
Yes, it shows up in Device Manager as "USB-SERIAL CH340 (COM4)", and I used the adapter to successfully update the ARM chip, so I think the adapter is fine.
do you download this newest version?
https://www.kincony.com/forum/attachment.php?aid=9769
(09-26-2026, 01:46 AM)admin Wrote: do you download this newest version?
Yes I've been using the newest version of this app (also newest ARM and KCS firmwares), but also tried an older version of this app too. Same problem, I only ever see "uiComboBox1" for the available port, and I can't connect.
can you use another PC to test?
Alternatively, please run the exe file with administrator privileges
