  • 1 Vote(s) - 5 Average
Lesson9 - integrate KC868-Server to home assistant by MQTT
1.MQTT communication structure diagram
KC868-Server--------
publish message: status of switch (status topic)
Subscription message: turn on / off command (command topic)
home assistant------
publish message:  turn on / off command (command topic)
Subscription message: status of switch (status topic)
2.KC868-Server digital output , digital input , analog input config sample code in configuration.yaml
# Example configuration.yaml entry
  - platform: mqtt
    unique_id: output-1
    state_topic: 'server/ xxxxxxxxxxxxxxxxxxxxxxxx /state'
    command_topic: 'server/ xxxxxxxxxxxxxxxxxxxxxxxx /set'
    payload_on:  '{"relay1":{"on":1}}'
    payload_off:  '{"relay1":{"on":0}}'
    state_on: 1
state_off: 0
  - platform: mqtt
    unique_id: input-1
    value_template: '{{ value_json.input1.on }}'
    payload_on: 1
    payload_off: 0
  - platform: mqtt
    unique_id: analog-1
    unit_of_measurement: 'v'
    value_template: '{{ value_json.analog1.value }} '
Note: xxxxxxxxxxxxxxxxxxxxxxxx is UID of controller, just replace with your device UID. You can find the UID in ethernet setting.
3.KC868-Server 16 channel output, 16 channel digital input, 4 channel analog input all use in configuration.yaml
.txt   KC868-Server-home-assistant-config.txt (Size: 8.15 KB / Downloads: 1,596)
I try to integrate KC868-Server to the home assistant by MQTT
but I can't find the IP for the server
the IP for  the home assistant is http://192.168.100.172:8123/
see the photo
https://ibb.co/G2V4wQc
https://ibb.co/47cJmTn
https://ibb.co/rMMmr19
can you help me find the IP
because your KC868-Server ip is 192.168.1.200
your network is 192.168.100.x
you should set KC868-Server ethernet for "DHCP" mode. let it's ip became 192.168.100.x so that you can find it.
how to set :
d.) Hold on Ethernet mode button, when the [yellow and white LED] all is ON, release it, then work mode in “UDP” and IP by DHCP mode;
here is online guide details: https://www.kincony.com/how-to-use-kc868-server.html
Than you  Working now Smile
I get error message
Your manually configured MQTT switch(s) needs attention
This stops working in version 2022.12.0. Please address before upgrading.
Manually configured MQTT switch(s) found under platform key
switch
Please move the configuration to the
mqtt
 integration key and restart Home Assistant to fix this issue. See the documentation, for more
yes, new home assistant version have changed mqtt format, you can see here:
https://www.kincony.com/forum/showthread.php?tid=1998
thank you
can you check attach
.txt   switch.txt (Size: 7.8 KB / Downloads: 691)
yes, whether work well with your config file?
Not working
which board you are using?
Kincony KC868-Server
