12-14-2023, 12:26 AM
item 1-2: water level sensor you can connect to A16S' digital input port.
item 3: motion detector can't use, it's AC220v version, it connect with AC220v lamp directly. you should chose dry contact output siganl version of PIR.
itme4: gas leak sensor: "relay output" of sensor connect to A16S' digital input port.
item5: not seen any pin define of the sensor, if the sensor have wire sigal output by "dry contact", also can use for A16S' digital input port.
