KC868-AIO ESP32 I/O pin define
I have a DS18b20 on GPIO14 and working. Trying to use a Dht11 on GPIO05.
The code I use (try) is:
one_wire:
  pin: GPIO14
  pin: GPIO05
Sensor
 - platform: dallas_temp
   name: #AIO DS18B20 #1"
   update_interval: 10s
   one_wire_id: one_wire1
 - platform: dht
    model: DHT11
    one_wire_id: one_wire2
    temperature:
    humidity:
The error I get is:
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome/aio.yaml...
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
See https://esphome.io/guides/faq.html#why-a...pping-pins
Failed config
sensor.dht: [source /config/esphome/aio.yaml:429]
  'pin' is a required option for [sensor.dht].
  platform: dht
  model: DHT11
  [one_wire_id] is an invalid option for [sensor.dht]. Please check the indentation.
  temperature:
  humidity:
What am I doing wrong? I am using 3.3v for Dht11. Tried 2 different sensors, both same error.
https://a.aliexpress.com/_EIdTg JK
https://a.aliexpress.com/_EQCKU9Q
(04-14-2025, 07:39 PM)xarouli5 Wrote: I have a DS18b20 on GPIO14 and working. Trying to use a Dht11 on GPIO05.
one_wire:
  pin: GPIO14
  pin: GPIO05
Sensor:
- platform: dht
    model: DHT11
    temperature:
    humidity:
The error I get is:
Failed config
  platform: dht
  model: DHT11
  temperature:
  humidity:
KC868-AIO ESP32 I/O pin define - by admin - 03-24-2023, 12:09 AM
RE: KC868-AIO ESP32 I/O pin define - by xarouli5 - 03-28-2025, 03:24 PM
RE: KC868-AIO ESP32 I/O pin define - by admin - 03-29-2025, 12:09 AM
RE: KC868-AIO ESP32 I/O pin define - by xarouli5 - 03-29-2025, 07:04 AM
RE: KC868-AIO ESP32 I/O pin define - by admin - 03-29-2025, 07:20 AM
RE: KC868-AIO ESP32 I/O pin define - by xarouli5 - 03-29-2025, 07:40 AM
RE: KC868-AIO ESP32 I/O pin define - by admin - 03-29-2025, 11:41 PM
RE: KC868-AIO ESP32 I/O pin define - by xarouli5 - 04-14-2025, 07:39 PM
RE: KC868-AIO ESP32 I/O pin define - by admin - 04-14-2025, 11:42 PM
RE: KC868-AIO ESP32 I/O pin define - by xarouli5 - 04-15-2025, 11:49 AM
RE: KC868-AIO ESP32 I/O pin define - by admin - 04-15-2025, 10:20 PM
