KC868-A6 Flow Control
Thank you for your quick response. I appreciate the information about the MS2548 chip used in the RS485 circuit.
I understand that the MS2548 likely provides Automatic Direction Control for the RS485 communication, which means a separate RTS/CTS signal is not needed for the RS485 interface.
Could you please confirm the following points?
RS485 Confirmation: Is it correct that the RS485 port on the KC868-A6 V1 4SP does not require an external RTS signal because its direction switching is managed automatically by the MS2548 chip?
RS232 Status: Can you confirm if the RS232 port on the KC868-A6 V1 4SP has the RTS and CTS pins available for hardware flow control? (My initial question did not receive a specific answer for RS232).
This confirmation is important for my device setup. Thank you once again for your assistance.
Best regards,
KC868-A6 Flow Control - by Edomicianoa - 11-04-2025, 04:47 PM
RE: KC868-A6 Flow Control - by admin - 11-04-2025, 08:21 PM
RE: KC868-A6 Flow Control - by Edomicianoa - 11-04-2025, 10:26 PM
RE: KC868-A6 Flow Control - by admin - 11-05-2025, 07:09 AM
