KCS v3 - Remote modification of Timer/IFTTT rules from Home Assistant
1. now only set IFTTT by KCS webpage. not support modify by API. But i will save your suggestion, maybe in future will do that.
2. not support now.
3. not support now.
4. if you set by IFTTT, if home assistant is broken, timer also can work. because the IFTTT commands on saved on ESP32, it work on esp32 side locally.
The pump turns ON at 09:00
The pump turns OFF at 23:00
why can't do this? KCS timer already support to do this.
KCS timer work in ESP32 locally, not need home assistant.it's not according to home assistant's time, the time running by our PCB.
RE: KCS v3 - Remote modification of Timer/IFTTT rules from Home Assistant - by admin - 06-19-2026, 10:43 PM
