06-19-2026, 11:20 PM
(06-19-2026, 10:43 PM)admin Wrote: 1. now only set IFTTT by KCS webpage. not support modify by API. But i will save your suggestion, maybe in future will do that.
2. not support now.
3. not support now.
4. if you set by IFTTT, if home assistant is broken, timer also can work. because the IFTTT commands on saved on ESP32, it work on esp32 side locally.
The pump turns ON at 09:00
The pump turns OFF at 23:00
why can't do this? KCS timer already support to do this.
KCS timer work in ESP32 locally, not need home assistant.it's not according to home assistant's time, the time running by our PCB.
It is not possible to set the logic of operation:
For example, if there is no internet connection and the time is between 9:00 and 18:00, then turn on the fountain.
It is not possible to set a time interval in the condition.
It will check that there is no internet connection, and if the time is 9:01, the condition will not be met.
Thousands of rules need to be set.
