KC868-M16v2 configure yaml for ESPhome
#91
(04-13-2025, 05:34 AM)admin Wrote: i use esphome compiled this BIN file, it use by ethernet, you can download to ESP32, test whether work well.
Do you use this yaml?
Thank you, using this .bin you provided i've been able to connect my M16-v2 to home assistant, instead the latest yaml still gives me errors while compiling
(03-06-2024, 11:39 AM)admin Wrote: do you install your home assistant on a raspberry pi? i suggest you delete your ESPhome, re install it.
it's correct as your photo about fold and files.
dears,
am using KC868-a16v3, and i have a webserver project that uses both wifi and Ethernet. i have tried every library to make it work, still it's not working. Can I get some advice on which library works and a sample code where i can work with to fix the issue? i started with esp32-eth01, which was working perfectly well, and i migrated to kc868-a16v3 and was stuck with no progress for weeks.
thansk in advance
w5500 ethernet chip demo source code for A16v3: https://www.kincony.com/forum/showthread.php?tid=7389
tested again with home assistant add-on ESPHome 2025.7.5
(08-25-2025, 11:07 PM)admin Wrote: tested again with home assistant add-on ESPHome 2025.7.5
What yaml are you using?
this is yaml file have tested.
.txt   M16v2-yaml-ESPHome.txt (Size: 9.26 KB / Downloads: 360)
(08-27-2025, 10:35 AM)admin Wrote: this is yaml file have tested.
Is this software compatible with the newest version of Home Assistant?
sure.
Hello Admin,
I just tried now the latest version but is it still not working. Attached screeshot.
[10:40:35][D][esp-idf:000]: E (538710) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:35][538717][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:35][538734][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:35][D][esp-idf:000]: E (538735) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:35][538742][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:35][538759][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:35][D][sensor:103]: 'm16--AI zmpt 39': Sending state 0.00000 V with 1 decimals of accuracy
[10:40:35][D][esp-idf:000]: E (538760) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:35][538777][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:35][538792][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:35][D][esp-idf:000]: E (538792) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:35][538799][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:35][538816][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:35][D][sensor:103]: 'm16--AI zmpt 36': Sending state 0.00000 V with 1 decimals of accuracy
[10:40:35][D][esp-idf:000]: E (538817) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:35][538834][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:35][538849][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:35][D][esp-idf:000]: E (538849) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:35][538856][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:35][538873][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:35][D][sensor:103]: 'm16--AI zmpt 34': Sending state 0.00000 V with 1 decimals of accuracy
[10:40:36][D][esp-idf:000]: E (539710) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:36][539717][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:36][539734][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:36][D][esp-idf:000]: E (539735) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:36][539741][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:36][539758][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:36][D][sensor:103]: 'm16--AI zmpt 39': Sending state 0.00000 V with 1 decimals of accuracy
[10:40:36][D][esp-idf:000]: E (539760) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:36][539776][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:36][539791][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:36][D][esp-idf:000]: E (539792) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:36][539799][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:36][539816][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:36][D][sensor:103]: 'm16--AI zmpt 36': Sending state 0.00000 V with 1 decimals of accuracy
[10:40:36][D][esp-idf:000]: E (539817) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:36][539834][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:36][539849][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:36][D][esp-idf:000]: E (539849) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
[10:40:36][539856][E][esp32-hal-adc.c:218] __analogInit(): adc_oneshot_new_unit failed with error: 261
[10:40:36][539873][E][esp32-hal-adc.c:275] __analogRead(): Analog initialization failed!
[10:40:36][D][sensor:103]: 'm16--AI zmpt 34': Sending state 0.00000 V with 1 decimals of accuracy
[10:40:36][D][sht3xd:095]: Got temperature=26.34°C humidity=66.59%
[10:40:36][D][sensor:103]: 'sht Temperature': Sending state 26.34051 °C with 1 decimals of accuracy
[10:40:36][D][sensor:103]: 'sht Humidity': Sending state 66.58884 % with 1 decimals of accuracy
[10:40:36][D][ct_clamp:041]: 'Measured Current-1' - Raw AC Value: 0.003A after 446 different samples (2230 SPS)
[10:40:36][D][sensor:103]: 'Measured Current-1': Sending state 0.00097 A with 2 decimals of accuracy
[10:40:37][D][esp-idf:000]: E (540710) adc_oneshot: adc_oneshot_new_unit(98): adc1 is already in use
