Threads: 0
(01-06-2026, 01:53 PM) admin Wrote: i see. esphome have updated. zmpt101b plugin we need to update again. we will update it, when finished, i will tell you, you just re compile code, not need to change yaml file.
thanks. much appreciated.
Threads: 1,282
zmpt101b plugin have updated. user "sensitivity" to calibration voltage. my test is "sensitivity: 538", you can try , maybe you need change it. Here is my yaml file, it will print 3 voltage values on the SSD1306 OLED. I have connect L1,L2,L3 together and N1,N2,N3 terminal together. Now you can re compile your code.
esp32:
board: esp32dev
framework:
type: arduino
external_components:
- source:
type: git
url: https://github.com/hzkincony/esphome-zmpt101b
refresh: 1min
encryption:
key: "D69bY/GXlmjYkovak6WIhgmbOH8vwyqvMxIHBriYoaY="
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
sda: 4
scl: 5
cd74hc4067:
- id: cd74hc4067_1
pin_s0: 32
pin_s1: 33
pin_s2: 13
pin_s3: 16
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "AC:%.1fV", id(voltage_1).state);
it.printf(0, 20, id(roboto), "AC:%.1fV", id(voltage_2).state);
it.printf(0, 40, id(roboto), "AC:%.1fV", id(voltage_3).state);
- platform: zmpt101b
name: "m16--AI zmpt 34"
adc_pin: 34
sensitivity: 538
unit_of_measurement: V
accuracy_decimals: 1
state_class: "measurement"
name: "m16--AI zmpt 36"
adc_pin: 36
sensitivity: 538
name: "m16--AI zmpt 39"
adc_pin: 39
sensitivity: 538
- platform: sht3xd
temperature:
name: "sht Temperature"
humidity:
name: "sht Humidity"
address: 0x44
update_interval: 5s
- platform: adc
pin: 35
update_interval: never
attenuation: 11db
# - platform: adc
# name: "m16--AI-1"
# pin: 36
# id: adc36
# update_interval: 60s
# attenuation: 11db
# - platform: adc
# pin: 34
# name: "m16--AI-2"
# id: adc34
# attenuation: 11db
# - platform: adc
# pin: 39
# name: "m16--AI-3"
# id: adc39
# attenuation: 11db
- platform: cd74hc4067
sensor: adc35
number: 1
sensor: adc35
number: 2
sensor: adc35
number: 3
sensor: adc35
number: 4
sensor: adc35
number: 5
sensor: adc35
number: 6
sensor: adc35
number: 7
sensor: adc35
number: 8
sensor: adc35
number: 9
sensor: adc35
number: 10
sensor: adc35
number: 11
sensor: adc35
number: 12
sensor: adc35
number: 13
sensor: adc35
number: 14
sensor: adc35
number: 15
sensor: adc35
- platform: ct_clamp
sensor: ai1
name: "Measured Current-1"
update_interval: 5s
filters:
- calibrate_linear:
# Measured value of 0 maps to 0A
- 0.0034 -> 0
# Known load: 4.0A
# Value shown in logs: 0.1333A
- 0.31749 -> 8.95608
- platform: template
lambda: return id(Measured_Current_1).state * id(voltage_1).state;
device_class: power
unit_of_measurement: 'W'
- platform: total_daily_energy
name: "Total Daily Energy1"
power_id: power1
filters:
- multiply: 0.001
unit_of_measurement: kWh
accuracy_decimals: 3
icon: mdi:clock-alert
device_class: energy
sensor: ai2
name: "Measured Current-2"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai3
name: "Measured Current-3"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai4
name: "Measured Current-4"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai5
name: "Measured Current-5"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai6
name: "Measured Current-6"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai7
name: "Measured Current-7"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai8
name: "Measured Current-8"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai9
name: "Measured Current-9"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai10
name: "Measured Current-10"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai11
name: "Measured Current-11"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai12
name: "Measured Current-12"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai13
name: "Measured Current-13"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai14
name: "Measured Current-14"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai15
name: "Measured Current-15"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai16
name: "Measured Current-16"
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
time:
- platform: sntp
Threads: 0
Managed to make some progress.
I've lost my current output. it shows Not Available.
My file is now similar to yours.
Image(s)
Threads: 1,282
you can also use your yaml file. what problem now? no "current"? take a photo of your issue.
Threads: 0
(01-10-2026, 12:43 AM) admin Wrote: you can also use your yaml file. what problem now? no "current"? take a photo of your issue.
my currents which worked just before the latest esphome changes is now not being recognized.
Image(s)
Threads: 1,282
the bug fixed. plugin updated plugin and yaml. you can use this yaml file directly.
The zmpt sensor has been disassembled into two parts: one is the original ADC sensor, and the other is the zmpt sensor.
The configuration parameters for zmpt plugin can be found here:
support set parameters : sensitivity/frequency/update_interval
esp32:
board: esp32dev
framework:
type: arduino
- source:
type: git
ref: v2.1.0
encryption:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
sda: 4
scl: 5
cd74hc4067:
- id: cd74hc4067_1
pin_s0: 32
pin_s1: 33
pin_s2: 13
pin_s3: 16
web_server:
port: 80
font:
display:
address: 0x3C
lambda: |-
- platform: adc
pin: 34
attenuation: 12db
- platform: adc
pin: 36
attenuation: 12db
- platform: adc
pin: 39
attenuation: 12db
sensor: adc34
sensitivity: 538
sensor: adc36
sensitivity: 538
sensor: adc39
sensitivity: 538
- platform: sht3xd
temperature:
humidity:
address: 0x44
update_interval: 5s
- platform: adc
pin: 35
attenuation: 12db
# - platform: adc
# name: "m16--AI-1"
# pin: 36
# id: adc36
# attenuation: 11db
# - platform: adc
# pin: 34
# name: "m16--AI-2"
# id: adc34
# attenuation: 11db
# - platform: adc
# pin: 39
# name: "m16--AI-3"
# id: adc39
# attenuation: 11db
sensor: adc35
number: 1
sensor: adc35
number: 2
sensor: adc35
number: 3
sensor: adc35
number: 4
sensor: adc35
number: 5
sensor: adc35
number: 6
sensor: adc35
number: 7
sensor: adc35
number: 8
sensor: adc35
number: 9
sensor: adc35
number: 10
sensor: adc35
number: 11
sensor: adc35
number: 12
sensor: adc35
number: 13
sensor: adc35
number: 14
sensor: adc35
number: 15
sensor: adc35
sensor: ai1
update_interval: 5s
filters:
- calibrate_linear:
- 0.0034 -> 0
# Known load: 4.0A
device_class: power
power_id: power1
filters:
- multiply: 0.001
sensor: ai2
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai3
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai4
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai5
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai6
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai7
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai8
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai9
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai10
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai11
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai12
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai13
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai14
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai15
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
sensor: ai16
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
time:
- platform: sntp
yaml file download:
M16v2_HA.txt (Size: 9.37 KB / Downloads: 65)
Threads: 12
02-17-2026, 08:40 PM
(This post was last modified: 02-17-2026, 08:40 PM by athxp .)
Hi,
I'm updating you on the situation with my m16v2:
- The LAN connection still isn't working. I'm only using the board via Wi-Fi. What a shame...
- The CT reading accuracy is "dirty." Even with the clamp disconnected, it can detect up to 0.3A.
- I modified the yaml file by inserting 16 entities to calculate power in W and 16 channels for energy calculation in kWh.
I then added a "filter" to prevent current readings below 0.3A from being calculated, as they would be false.
It's a shame because the board can't actually detect power below 50-60W with sufficient accuracy.
Threads: 1,282
if you really can't work with M16v2. we can send you a N20 energy meter board, it's new version.
Threads: 12
No, the card won't work below 50-60W. It gets dirty readings with disconnected sensors, even at 0.30A.
Can you send me an M20 card to replace the M16v2?
Threads: 1,282
send me your order number, we will send you a new N20, the old M16v2 board you not need send back to us.
