[Arduino IDE demo source code for KC868-A16]--#09-KC868-A16_Web_server_code
#11
Hello
I have a KC868-A16
I've recently performed an update
KCS_KC868_A16_V2.2.2.bin
The LEDs on the Ethernet interface are now lit
but I still get the error message
  WebServer.ino - Simple Arduino web server sample for Ethernet shield
  For Ethernet shields using WT32_ETH01 (ESP32 + LAN8720)
  WebServer_WT32_ETH01 is a library for the Ethernet LAN8720 in WT32_ETH01 to run WebServer
  Based on and modified from ESP8266 https://github.com/esp8266/Arduino/releases
  Built by Khoi Hoang https://github.com/khoih-prog/WebServer_WT32_ETH01
  Licensed under MIT license
#define DEBUG_ETHERNET_WEBSERVER_PORT      Serial
// Debug Level from 0 to 4
#define _ETHERNET_WEBSERVER_LOGLEVEL_      3
#include <WebServer_WT32_ETH01.h>
WiFiServer server(80);
// Select the IP address according to your local network
IPAddress myIP(192, 168, 2, 232);
IPAddress myGW(192, 168, 2, 1);
IPAddress mySN(255, 255, 255, 0);
// Google DNS Server IP
IPAddress myDNS(8, 8, 8, 8);
In file included from /tmp/.arduinoIDE-unsaved2025212-12431-f36wql.f8x/WebServer/WebServer.ino:19:
/home/arduino/Arduino/libraries/WebServer_WT32_ETH01/src/WebServer_WT32_ETH01.h:63:4: error: #error This code is designed to run on ESP32 platform! Please check your Tools->Board setting.
  63 |  #error This code is designed to run on ESP32 platform! Please check your Tools->Board setting.
exit status 1
Compilation error: exit status 1
Hello
I have a KC868-A16
exit status 1
if you have downloaded KCS firmware, just directly to use board, NOT need to use arduino.
Yes, that's true, but it was meant to be a test!
I have a finished Arduino program!
My program runs perfectly with WiFi!
But I'd rather connect via Ethernet!
But when I include
I always get the error message!!!
exit status 1
The yellow and green LEDs on the Ethernet port are always off.
I need your help. I've tested various programs in the examples, and I always get the same error.
But when I include
exit status 1
Hi,
I had the same issue than @wolli.
It looks like the WebServer_WT32_ETH01 library is incompatible with versions 3.x of Board Manager from ESP32 Espressif.
If you install version 2.0.17 of Board Manager from ESP32 Espressif and use the code from https://www.kincony.com/forum/showthread...31#pid8831 it compile and work fine.
Anyway, it will be good if Kincony support will find a way to use the recent versions Board Manager from ESP32 Espressif.
Hi
Thank you very much for your reply
lusant@
Now I can load the sketch but
I get an error message,
Starting WebClient on ESO32_Dev with ETH_PHY_LAN8720
Webserver_WT32_ETH01 v1,5,1 for core v2.0.0
E (1024) esp.emac: emac_esp32_init(357): reset timeout
E (1024) esp_eth: esp_eth_driver_install(214): init failed
and that for both example scripts
  KC868-A16_Web_Server_Eth.zip (Size: 413.26 KB / Downloads:
  or
  WebClient.ino - Simple Arduino web server sample for Ethernet shield
I would be grateful for further help
C:\Users\AYOO\Downloads\KC868-A16_Web_Server\KC868-A16_Web_Server\KC868-A16_Web_Server.ino:50:36: error: no matching function for call to 'PCF8574:TongueCF8574(TwoWire*, int, int, int)'
50 | PCF8574 pcf8574_I1(&I2Cone,0x3A,4,5);
In file included from C:\Users\AYOO\Downloads\KC868-A16_Web_Server\KC868-A16_Web_Server\KC868-A16_Web_Server.ino:8:
c:\Users\AYOO\Documents\Arduino\libraries\PCF8574/PCF8574.h:30:12: note: candidate: 'PCF8574:TongueCF8574(uint8_t, TwoWire*)'
30 | explicit PCF8574(const uint8_t deviceAddress = 0x20, TwoWire *wire = &Wire);
c:\Users\AYOO\Documents\Arduino\libraries\PCF8574/PCF8574.h:30:12: note: candidate expects 2 arguments, 4 provided
c:\Users\AYOO\Documents\Arduino\libraries\PCF8574/PCF8574.h:27:7: note: candidate: 'constexpr PCF8574:TongueCF8574(const PCF8574&)'
27 | class PCF8574
here is PCF8574 arduino library we have used.
.zip   PCF8574_library.zip (Size: 23.8 MB / Downloads: 604)
Errors are resolved .
But, 192.168.3.182 web portal timeout error.
17:14:07.203 -> *wm:AutoConnect
17:14:07.203 -> *wm:AutoConnect: ESP Already Connected
17:14:07.203 -> *wm:AutoConnect: SUCCESS
17:14:07.203 -> *wm:STA IP Address: 192.168.3.182
17:14:07.203 -> WiFi connected!
17:14:07.203 -> IP: 192.168.3.182
17:14:07.203 ->
17:14:07.203 -> WiFi connected.
17:14:07.203 -> IP address:
17:14:07.236 -> 192.168.3.182
