Threads: 1,277
because you have chose the chip model is ESP8266, not ESP32. today i will make a tasmota firmware for you, use by KC868-A6 directly.
Threads: 0
03-12-2023, 03:45 PM
(This post was last modified: 03-12-2023, 06:30 PM by andrusha778.)
Hi! Can U please post template for Tasmota firmware for this controller, and content of user_config_override.h file, so it will be able to compile new versions of firmware (including settings for displays and all other supported hardware).
And another question - which GPIO in Tasmota should I use to take data from INA-219 i2c controller (should connect it to IIC bus) and PZEM-004T energy meter (want to connect it to serial interface on board and make PZEM-004T 3.3v tolerant)?
Threads: 0
Hi! This published Tasmota FW version is 12.2.0
By the way, Tasmota has updated to release 12.4.0
I cannot do OTA update, because U have compiled custom firmware with some additional settings to tasmota32 repo in user_config_override.h file.
So it would be great, if U will post content of user_config_override.h file to everybody and paste template with description of GPIO in Tasmota settings, after that it will be much easy to compile new builds and do tasmota firmware updates.
