Threads: 3
Please let me know any solution
Threads: 1,489
do you use by sinric.com ?
Threads: 0
(09-10-2021, 12:06 AM)admin Wrote: do you use by sinric.com ? Sinric will stop soon
only sinric pro
can you provide solution to use sinric pro?
Threads: 0
I have followed the instructions to install alexa without third party. But it did not work due to discovery error
Can I go back to senric
I tried sinric, it is not working anymore. Do I need to restore the original firmware before flashing the one in this thread (alexa without 3rd party)
Can you provide the original firmware please?
Threads: 1,489
you can see this video, work without sinric: https://youtu.be/_w_jyZHOEEQ
Threads: 1
This works fine for me. Thanks
Code: #ifdef ARDUINO_ARCH_ESP32
#include <WiFi.h>
#else
#include <ESP8266WiFi.h>
#endif
#define ESPALEXA_MAXDEVICES 32
#include <Espalexa.h>
#define R2 2
// prototypes
boolean connectWifi();
//callback functions
void F1LightChanged(uint8_t brightness);
void F2LightChanged(uint8_t brightness);
void F3LightChanged(uint8_t brightness);
void F4LightChanged(uint8_t brightness);
void F5LightChanged(uint8_t brightness);
void F6LightChanged(uint8_t brightness);
void F7LightChanged(uint8_t brightness);
void F8LightChanged(uint8_t brightness);
void F9LightChanged(uint8_t brightness);
void F10LightChanged(uint8_t brightness);
void F11LightChanged(uint8_t brightness);
void F12LightChanged(uint8_t brightness);
void F13LightChanged(uint8_t brightness);
void F14LightChanged(uint8_t brightness);
void F15LightChanged(uint8_t brightness);
void F16LightChanged(uint8_t brightness);
void F17LightChanged(uint8_t brightness);
void F18LightChanged(uint8_t brightness);
void F19LightChanged(uint8_t brightness);
void F20LightChanged(uint8_t brightness);
void F21LightChanged(uint8_t brightness);
void F22LightChanged(uint8_t brightness);
void F23LightChanged(uint8_t brightness);
void F24LightChanged(uint8_t brightness);
void F25LightChanged(uint8_t brightness);
void F26LightChanged(uint8_t brightness);
void F27LightChanged(uint8_t brightness);
void F28LightChanged(uint8_t brightness);
void F29LightChanged(uint8_t brightness);
void F30LightChanged(uint8_t brightness);
void F31LightChanged(uint8_t brightness);
void F32LightChanged(uint8_t brightness);
// Change this!!
// WiFi Credentials
const char* ssid = "1111";
const char* password = "2222";
// device names
String Device_1_Name = "luce 1";
String Device_2_Name = "luce 2";
String Device_3_Name = "luce 3";
String Device_4_Name = "luce 4";
String Device_5_Name = "luce 5";
String Device_6_Name = "luce 6";
String Device_7_Name = "luce 7";
String Device_8_Name = "luce 8";
String Device_9_Name = "luce 9";
String Device_10_Name ="luce 10";
String Device_11_Name ="luce 11";
String Device_12_Name ="luce 12";
String Device_13_Name ="luce 13";
String Device_14_Name ="luce 14";
String Device_15_Name ="luce 15";
String Device_16_Name ="luce 16";
String Device_17_Name ="luce 17";
String Device_18_Name ="luce 18";
String Device_19_Name ="luce 19";
String Device_20_Name ="luce 20";
String Device_21_Name ="luce 21";
String Device_22_Name ="luce 22";
String Device_23_Name ="luce 23";
String Device_24_Name ="luce 24";
String Device_25_Name ="luce 25";
String Device_26_Name ="luce 26";
String Device_27_Name ="luce 27";
String Device_28_Name ="luce 28";
String Device_29_Name ="luce 29";
String Device_30_Name ="luce 30";
String Device_31_Name ="luce 31";
String Device_32_Name ="luce 32";
unsigned long Millis = 0;
unsigned long PreviousMillis = 0;
boolean Initialized = false;
boolean wifiConnected = false;
Espalexa espalexa;
void setup()
pinMode(R2, OUTPUT);
pinMode(R2, LOW);
PreviousMillis = millis();
// Initialise wifi connection
wifiConnected = connectWifi();
if (wifiConnected)
// Define your devices here.
espalexa.addDevice(Device_1_Name,F1LightChanged);
espalexa.addDevice(Device_2_Name,F2LightChanged);
espalexa.addDevice(Device_3_Name,F3LightChanged);
espalexa.addDevice(Device_4_Name,F4LightChanged);
espalexa.addDevice(Device_5_Name,F5LightChanged);
espalexa.addDevice(Device_6_Name,F6LightChanged);
espalexa.addDevice(Device_7_Name,F7LightChanged);
espalexa.addDevice(Device_8_Name,F8LightChanged);
espalexa.addDevice(Device_9_Name,F9LightChanged);
espalexa.addDevice(Device_10_Name,F10LightChanged);
espalexa.addDevice(Device_11_Name,F11LightChanged);
espalexa.addDevice(Device_12_Name,F12LightChanged);
espalexa.addDevice(Device_13_Name,F13LightChanged);
espalexa.addDevice(Device_14_Name,F14LightChanged);
espalexa.addDevice(Device_15_Name,F15LightChanged);
espalexa.addDevice(Device_16_Name,F16LightChanged);
espalexa.addDevice(Device_17_Name,F17LightChanged);
espalexa.addDevice(Device_18_Name,F18LightChanged);
espalexa.addDevice(Device_19_Name,F19LightChanged);
espalexa.addDevice(Device_20_Name,F20LightChanged);
espalexa.addDevice(Device_21_Name,F21LightChanged);
espalexa.addDevice(Device_22_Name,F22LightChanged);
espalexa.addDevice(Device_23_Name,F23LightChanged);
espalexa.addDevice(Device_24_Name,F24LightChanged);
espalexa.addDevice(Device_25_Name,F25LightChanged);
espalexa.addDevice(Device_26_Name,F26LightChanged);
espalexa.addDevice(Device_27_Name,F27LightChanged);
espalexa.addDevice(Device_28_Name,F28LightChanged);
espalexa.addDevice(Device_29_Name,F29LightChanged);
espalexa.addDevice(Device_30_Name,F30LightChanged);
espalexa.addDevice(Device_31_Name,F31LightChanged);
espalexa.addDevice(Device_32_Name,F32LightChanged);
espalexa.begin();
else
while (1)
Serial.println("Cannot connect to WiFi. Please check data and reset the ESP.");
delay(5000);
void loop()
espalexa.loop();
delay(1);
//our callback functions
//Control the device
if (brightness)
if (brightness == 255)
Serial.println("RELAY-SET-255,1,1");
digitalWrite(R2, HIGH);
//Serial.print("ON, brightness ");
//Serial.println(brightness);
else
Serial.println("RELAY-SET-255,1,0");
digitalWrite(R2, LOW);
if (brightness)
Serial.println("RELAY-SET-255,2,1");
else
Serial.println("RELAY-SET-255,2,0");
if (brightness)
Serial.println("RELAY-SET-255,3,1");
else
Serial.println("RELAY-SET-255,3,0");
if (brightness)
Serial.println("RELAY-SET-255,4,1");
else
Serial.println("RELAY-SET-255,4,0");
if (brightness)
Serial.println("RELAY-SET-255,5,1");
else
Serial.println("RELAY-SET-255,5,0");
if (brightness)
Serial.println("RELAY-SET-255,6,1");
else
Serial.println("RELAY-SET-255,6,0");
if (brightness)
Serial.println("RELAY-SET-255,7,1");
else
Serial.println("RELAY-SET-255,7,0");
if (brightness)
Serial.println("RELAY-SET-255,8,1");
else
Serial.println("RELAY-SET-255,8,0");
if (brightness)
Serial.println("RELAY-SET-255,9,1");
else
Serial.println("RELAY-SET-255,9,0");
if (brightness)
Serial.println("RELAY-SET-255,10,1");
else
Serial.println("RELAY-SET-255,10,0");
if (brightness)
Serial.println("RELAY-SET-255,11,1");
else
Serial.println("RELAY-SET-255,11,0");
if (brightness)
Serial.println("RELAY-SET-255,12,1");
else
Serial.println("RELAY-SET-255,12,0");
if (brightness)
Serial.println("RELAY-SET-255,13,1");
else
Serial.println("RELAY-SET-255,13,0");
if (brightness)
Serial.println("RELAY-SET-255,14,1");
else
Serial.println("RELAY-SET-255,14,0");
if (brightness)
Serial.println("RELAY-SET-255,15,1");
else
Serial.println("RELAY-SET-255,15,0");
if (brightness)
Serial.println("RELAY-SET-255,16,1");
else
Serial.println("RELAY-SET-255,16,0");
if (brightness)
Serial.println("RELAY-SET-255,17,1");
else
Serial.println("RELAY-SET-255,17,0");
if (brightness)
Serial.println("RELAY-SET-255,18,1");
else
Serial.println("RELAY-SET-255,18,0");
if (brightness)
Serial.println("RELAY-SET-255,19,1");
else
Serial.println("RELAY-SET-255,19,0");
if (brightness)
Serial.println("RELAY-SET-255,20,1");
else
Serial.println("RELAY-SET-255,20,0");
if (brightness)
Serial.println("RELAY-SET-255,21,1");
else
Serial.println("RELAY-SET-255,21,0");
if (brightness)
Serial.println("RELAY-SET-255,22,1");
else
Serial.println("RELAY-SET-255,22,0");
if (brightness)
Serial.println("RELAY-SET-255,23,1");
else
Serial.println("RELAY-SET-255,23,0");
if (brightness)
Serial.println("RELAY-SET-255,24,1");
else
Serial.println("RELAY-SET-255,24,0");
if (brightness)
Serial.println("RELAY-SET-255,25,1");
else
Serial.println("RELAY-SET-255,25,0");
if (brightness)
Serial.println("RELAY-SET-255,26,1");
else
Serial.println("RELAY-SET-255,26,0");
if (brightness)
Serial.println("RELAY-SET-255,27,1");
else
Serial.println("RELAY-SET-255,27,0");
if (brightness)
Serial.println("RELAY-SET-255,28,1");
else
Serial.println("RELAY-SET-255,28,0");
if (brightness)
Serial.println("RELAY-SET-255,29,1");
else
Serial.println("RELAY-SET-255,29,0");
if (brightness)
Serial.println("RELAY-SET-255,30,1");
else
Serial.println("RELAY-SET-255,30,0");
if (brightness)
Serial.println("RELAY-SET-255,31,1");
else
Serial.println("RELAY-SET-255,31,0");
if (brightness)
Serial.println("RELAY-SET-255,32,1");
else
Serial.println("RELAY-SET-255,32,0");
// connect to wifi – returns true if successful or false if not
boolean state = true;
int i = 0;
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
Serial.println("Connecting to WiFi");
// Wait for connection
Serial.print("Connecting...");
while (WiFi.status() != WL_CONNECTED) {
delay(500);
// Serial.print(".");
if (i > 20) {
state = false; break;
i++;
Serial.println("");
if (state) {
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
pinMode(R2, HIGH);
else {
Serial.println("Connection failed.");
pinMode(R2, LOW);
return state;
Threads: 0
Hello, i updated the kc 868 h32b with the last firmware and i changed the code of the ESP8266 for 32 relay, as you showed in your video, but the Board crash when i use Alexa Routines, and i can’t turn on or off the lights with the buttons, and i need to reboot all.
If i turn on/off lights with alexa one at a time, it works
In the attached video, i asked to Alexa to turn on all lights, and the board crash, i can’t turn on or off the lights with the buttons.
Then i asked to turn on and off lights one at a time, and it works.
In the end i asked to turn off all lights, and the board turned off only 2-3 light, and not all of them.
Threads: 1,489
Can you try the above arduino code? now we suggest use raspberry pi running Node-Red for alexa or google home. because sinric.com not free now.
Threads: 0
(10-04-2021, 12:04 AM)admin Wrote: Can you try the above arduino code? now we suggest use raspberry pi running Node-Red for alexa or google home. because sinric.com not free now.
#include <WiFi.h>
#else
#endif
#define R2 2
// prototypes
// Change this!!
// WiFi Credentials
const char* ssid = "----SSID----";
const char* password = "----PASSWORD----";
// device names
String Device_1_Name = "luce salotto 1";
String Device_2_Name = "luce salotto 2";
String Device_3_Name = "luce cucina";
String Device_4_Name = "luce antibagno giorno";
String Device_5_Name = "luce bagno giorno";
String Device_6_Name = "luce corridoio";
String Device_7_Name = "luce camera";
String Device_8_Name = "luce studio";
String Device_9_Name = "luce bagno notte";
String Device_10_Name ="luce balcone";
String Device_11_Name ="luce portico";
String Device_12_Name ="luce giardino";
String Device_13_Name ="luce scala";
String Device_14_Name ="luce sottoscala";
String Device_15_Name ="luce cantina";
String Device_16_Name ="luce garage";
String Device_17_Name ="rele 17";
String Device_18_Name ="rele 18";
String Device_19_Name ="rele 19";
String Device_20_Name ="monitor";
String Device_21_Name ="rele 21";
String Device_22_Name ="rele 22";
String Device_23_Name ="rele 23";
String Device_24_Name ="rele 24";
String Device_25_Name ="rele 25";
String Device_26_Name ="rele 26";
String Device_27_Name ="rele 27";
String Device_28_Name ="rele 28";
String Device_29_Name ="rele 29";
String Device_30_Name ="rele 30";
String Device_31_Name ="rele 31";
String Device_32_Name ="rele 32";
//unsigned long Millis = 0;
//unsigned long PreviousMillis = 0;
//boolean Initialized = false;
Espalexa espalexa;
void setup()
pinMode(R2, LOW);
//PreviousMillis = millis();
if (wifiConnected)
espalexa.begin();
else
while (1)
delay(2500);
void loop()
espalexa.loop();
delay(1);
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
int i = 0;
//Serial.println("");
//Serial.println("Connecting to WiFi");
//Serial.print("Connecting...");
delay(500);
if (i > 20) {
i++;
if (state) {
//Serial.print("Connected to ");
//Serial.print("IP address: ");
pinMode(R2, HIGH);
else {
//Serial.println("Connection failed.");
pinMode(R2, LOW);
return state;
Threads: 0
Do you have any news about my problem with Alexa Routines?
thanks
0615721063Dth
