Threads: 1,373
sure, every channel should use different CT sensor according to your MAX current.
Threads: 1,373
Yes, there are calibration configurations in the program, which parameters can be modified.
filters:
- calibrate_linear:
# Measured value of 0 maps to 0A
- 0 -> 0
# Known load: 4.0A
# Value shown in logs: 0.1333A
- 0.31749 -> 8.95608
you can test some different load, create as many as possible with different scale parameters:
such as:
filters:
- calibrate_linear:
- 0 -> 0
- x.xxxxx -> 3
- x.xxxxx -> 6
- x.xxxxx -> 9
- x.xxxxx -> 15
- x.xxxxx -> 18
The more parameters, the more accurate they are.
Threads: 1,373
you can download by USB cable.
Threads: 1,373
lambda: return id(Measured_Current_1).state * 220; this is only for CT1, if you want feedback 16CH CT's total power, need sum of all CT's power.
Threads: 1,373
id(Measured_Current_2).state * 220
id(Measured_Current_3).state * 220
id(Measured_Current_4).state * 220
then all add together.
