Threads: 1,371
thanks for suggestion, we will update it in furture.
Threads: 0
I bought 3 of these boards and the ds1307 is faulty on all 3 boards. The time cannot be set correctly using the KCS firmware or with the arduino test linked on the previous page of this thread. Taking the battery out didn't help . I tried removing the diodes and adding a jumper on one board but that let the battery power the whole board when the power supply was removed and it didn't help with setting clock. That solution did not work for me.
So all 3 of these boards are basically useless for what I wanted them for without the rtc functioning correctly. I don't have the gear to reflow solder a new chip to the board, so the only way I could use them will be to use an external clock on the I2C port.
This caused me a lot of frustration, I wasted nearly two days just trying to get these things functioning and in the end I had to give up because I was sold faulty hardware.
Threads: 1,371
can you test with our arduino source code of DS1307? do you write your own arduino code or config by ESPHome?
if want have good RTC, suggest chose KC868-A6v3 , new V3 board use by DS3231 RTC chip, not use DS1307 again.
