Threads: 1,529
This is strange. If you want, we can re send you a new KC868-A4 board (if you bought A4 from KinCony Official Aliexpress online store)
Threads: 3
This is strange.
I agree. in same time A16S work properly via lan all time.
-i have problems with A8, not A4
Unfortunately, i bought it not in official store
my be this happens because i read data from A8 very often? in fact i read data every 5 seconds to control temperature and valve state
if you can connect to me by Anydesk i can show you my stream in NodeRed
may be you can show me another way?
Threads: 1,529
if you download KCS firmware, use by MQTT, then you disable all others protocol.
you can test work without Node-Red for one day. such as every some hours later, you login with board's ip address.
Threads: 0
Hi. Is there a solution to the problem? I use two A8 modules. The first one rarely loses connection, and the second one disconnects at random intervals from about 30 minutes to 2-3 hours. Both modules are powered by the same 12v power supply and replacing the power supply did not help. When disconnected, the indicators on the network connector light up without blinking. Maybe it freezes?.. The problem appears more and more often over time, does it make sense to look for problems in the firmware?..
Threads: 1,529
can you test with esphome yaml or KCS firmware?
another test way, whether wifi is stable? or only have issue with ethernet?
Threads: 1,529
suggest you test by wifi, if wifi is ok, maybe you need re weld your ethernet chip: LAN8720A
