V2.2.2 will not flash anymore
#11
Yes. I always power off/on after I flash.
This is getting frustrating.
I have gone back and tried every version from 1.0.24 to 2.2.4. If they are a fresh copy from your site, they flash but cannot be detected.
If I flash from a previous copy that I saved via the esptool where I was able to detect and set the IP address for my network, they work.
The only thing that has changed in the interim is that I flashed it with an ESPHOME configuration from esphome version 2024.6.4
It is after that that your version of the firmware flashes but are unable to be detected.
can you take a video of whole progress. i can do as your all steps.
video send to whatsapp number: 86-15381188302
sorry I don't have Whatsapp.
Media 1 is flashing with Flash download tool 3.9.2
Media 2 is powering off/on board.
Media 3 is using scan tool to detect board. Board is not detected.
This is all the time I am going to spend with this problem.
My worry is that the same thing will happen to my AM and A64 boards, so I am afraid to touch them.
Will leave them with ESPHOME for now, since there seems to be a problem with the KCS firmware.
.zip   Media3.zip (Size: 5.35 MB / Downloads: 430)
.zip   Media1.zip (Size: 15.37 MB / Downloads: 431)
.zip   Media2.zip (Size: 2.37 MB / Downloads: 427)
I was able to solve my problem.
you solved your problem?
yeah, apparently when a static IP address is set, you store it somewhere in flash memory that doesn't get erased when the chip is re-flashed.
After detecting that I had duplicate IP addresses and changing other devices away from where the A16 was originally addressed, I was able to reflash and access it at the original address.
Scan tool could not detect it, but I was able to get back in to a fresh v2.2.2 and reconfigure it.
I let you guys figure out the why.
now how to eraser it?
do you have download KCS firmware firstly?
you can see KCS v2 firmware online guide at here: https://www.kincony.com/esp32-kcsv2-firmware.html
you can also post your screen images at here is have issue.
yea i've done all of that. it does not work
