analog input resolution 30%erro
#11
Hi, I seem to have the same problem with my board KC868-A16. You can read about it here
https://www.kincony.com/forum/showthread.php?tid=7421
we have checked, we will fixed this issue in next KCS firmware update.
Hello Decilitr,
Thanks for your feedback.
For me there is not only that to correct, see my posts...
For the admin :
When can we expect a firmware ?
There is also a problem with TH22 see my post..
and NTP
Regards
Board : K868-A16
Firmware :  v2.2.12
when release new firmware, when have news, i will update.
your sensor quesitons repied on your another thread.
NTP also we will check.
Thank you so much
Board : K868-A16
Firmware :  v2.2.12
I am having the same issue with both current and voltage measurement, but the voltage measurement is worse, as shown in the attached test record.
KC868-A16
Firmware: V2.2.12
.xlsx   A16 Analog test record.xlsx (Size: 58.23 KB / Downloads: 443)
Hello
have you advance on this subject (news firmware)
Board : K868-A16
Firmware :  v2.2.12
