KC868 SHT30 Homeassistant
#11
friendly_name: KC868-A16
esp32:
board: esp32dev
framework:
type: arduino
encryption:
key: "key"
ota:
- platform: esphome
password: "key"
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
use_address: 192.168........
# wifi:
# ssid: !secret wifi_ssid
# password: !secret wifi_password
# ap:
# ssid: "Kc868-A16 Fallback Hotspot"
# password: "########"
uart:
- id: uart_modbus
tx_pin: GPIO13
rx_pin: GPIO16
baud_rate: 9600
remote_receiver:
number: GPIO2
ignore_strapping_warning: true
remote_transmitter:
number: GPIO15
carrier_duty_percent: 100%
# Config Modbus
modbus:
uart_id: uart_modbus
modbus_controller:
- id: modbus_sensor
address: 0x01 # device address
modbus_id: modbus1
sda: GPIO4
scl:
number: GPIO5
pcf8574:
- id: inputs_1_8
address: 0x22
pcf8575: false
- id: inputs_9_16
address: 0x21
pcf8575: false
- id: outputs_1_8
address: 0x24
pcf8575: false
- id: outputs_9_16
address: 0x25
pcf8575: false
number: GPIO32
number: GPIO33
number: GPIO14
pcf8574: inputs_1_8
mode: INPUT
pcf8574: inputs_1_8
number: 1
mode: INPUT
pcf8574: inputs_1_8
number: 2
mode: INPUT
pcf8574: inputs_1_8
number: 3
mode: INPUT
pcf8574: inputs_1_8
number: 4
mode: INPUT
pcf8574: inputs_1_8
number: 5
mode: INPUT
pcf8574: inputs_1_8
number: 6
mode: INPUT
pcf8574: inputs_1_8
number: 7
mode: INPUT
pcf8574: inputs_9_16
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
pcf8574: outputs_1_8
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: outputs_9_16
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
# substitutions:
# update_interval: 1s
- platform: modbus_controller
modbus_controller_id: modbus_sensor
address: 0x0000
register_type: holding
value_type: U_WORD
unit_of_measurement: "°C"
accuracy_decimals: 1
filters:
- throttle_average: 1s
- lambda: if (x < 10000) return x * 0.1; else return -1 * (x - 10000) * 0.1;
# - throttle_average: ${update_interval}
address: 0x0001
value_type: U_WORD
unit_of_measurement: "%"
filters:
- multiply: 0.1
web_server:
port: 80
mqtt:
broker: 192.168........
username: '#########'
password: '#########'
discovery: False # disable entity discovery
discover_ip: True # enable device discovery
