Threads: 1,546
if add the resistor can turn off. it's ok, it can work with long time, no problem. just reduce the voltage when dimmer output = 0%
Threads: 2
ok thank you, will do that
Threads: 1
Is there any reliable DIN mount 0-10V Driver known?
I was looking on the internet but nothing found.
Threads: 1
Thanks a lot, Kincony !
I was talking about the first product (0-10V Led Driver) but in format for DIN mount.
Otherwise, I don't know how to organize 8-10 pcs in the cabinet.
Threads: 0
Hello, did anybody managed to solve this problem ? When i connect driver , i still have 0.5-0.6 v on chanell , where should be 0 v in off position.
Threads: 1,546
We strongly recommend using Kincony's driver, otherwise there may be compatibility issues with drivers from different brands. Kincony's driver has been tested with DM series products. If there are any issues with using the Kincony driver, please take a photo and upload it, and we will provide technical support.
Threads: 0
Kincony does not have Constant Current drivers.
In your video You are using Ai Dimming driver with DM series and everything works. I am using Ai Dimming driver too.
So maybe somebody knows answer , how to make 0 v in chanel when off ?
Threads: 1,546
this "Ai Dimming driver" is 3 years ago, maybe it's different as yours .
