Threads: 1,560
do you using KC868-H32 or KC868-H32B? can you take a photo of your controller? because only KC868-H32B support MQTT.
Threads: 1
09-21-2022, 07:49 AM
(This post was last modified: 09-21-2022, 07:52 AM by juan.)
I'm sorry, I actually use the KC868-H32B controller, in fact, if I connect to the MQTT server directly, I can see how the states of the relays and inputs are published, but I cannot act on it from the home assistant. From a third-party application such as MQTT explorer, I can modify the states of the relays by publishing directly on the MQTT server, so I understand that the problem is on the Home Asisstant side.
Threads: 1,560
you can re-install your mosquito on home assistant, maybe not config mqtt broker ip correctly.
Threads: 1
Threads: 1
I just realized that there is a newer version of the KC868-H32B firmware, which just addresses issues with MQTT.
I will update the firmware and will post will try again.
As soon as I have done it I will tell you the results.
Threads: 1,560
ok, in furture when you post photo, please click "insert to" button, so that will add to article, auto size the photo.
Threads: 1
ok, sorry, the forums are new to me.
The problem was in the firmware version of the KC868-H32B, updating to version 4.44 already solved the problem and it works perfectly.
I hope this information can be useful to other people.
thanks again and greetings.
Threads: 0
Greetings,
How can the original KC868-Hx (1st versions) be integrated in homeassistant, since they won't work with mqtt?
Threads: 1,560
the old version not support MQTT, not suggest integrate to home assistant, that will not very easy.
