ESP32 RF
#21
Hi,
Did u test it?
And if i want to reset the ESP32 on the server fully can i use the online github tool?
Or better de flash tool? And wich image files do i need to select?
Thx in advance
i have tested code, sorry for my before error photo.
just set serial1 pin define as these will be work fine. here is photo.
#ifndef RX1
#define RX1 16
#endif
#ifndef TX1
#define TX1 17
#endif
if you want to eraser all esp32 data, you can use ESP Tool: https://www.kincony.com/esp-module-flash...tools.html
Hi!
I put back the factory bin then i put the pins as you sayd..
And it works!
Thx!! (happy happy)
ok, good.
Hi,
I hope simple question ;-)
i have temp sensor a dalles connected to the IO4 from esp32 on the KC868-server..
its a python question the relay for the serial print of the temperature i want it delayed 5000ms
but the control also delays 5000ms.. (that i realy dont want ;-))
for now i was only using RF but in time i maybe want a IR remote so it would be nice if RF and IR have NO delays...
Thx in advance!
here's my code test code:
#include <RCSwitch.h>
#include "PinDefinitionsAndMore.h"
#include <IRremote.h>
#include <OneWire.h>
#include <DallasTemperature.h>
long int keycode=0;
long int temp_keycode=0;
const int oneWireBus = 19;
OneWire oneWire(oneWireBus);
DallasTemperature sensors(&oneWire);
void setup()
Serial.begin(9600);
Serial1.begin(38400);
mySwitch.enableReceive(digitalPinToInterrupt(13));
sensors.begin();
IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK, USE_DEFAULT_FEEDBACK_LED_PIN);
if (mySwitch.available()) {
Serial.print("Received ");
delay(0);
Serial.print(" / ");
Serial.print("bit ");
Serial.print("Protocol: ");
keycode=mySwitch.getReceivedValue();
if (keycode==5723139) {Serial1.print("RELAY-KEY-255,1,1");delay(100);} //toggle relay1
if (keycode==5723148) {Serial1.print("RELAY-KEY-255,2,1");delay(500);} //toggle relay2
if (keycode==5723184) {Serial1.print("RELAY-KEY-255,3,1");delay(500);} //toggle relay3
if (keycode==5723340) {Serial1.print("RELAY-KEY-255,4,1");delay(500);} //toggle relay4
if (keycode==5723343) {Serial1.print("RELAY-KEY-255,5,1");delay(500);} //toggle relay5
if (keycode==5723196) {Serial1.print("RELAY-KEY-255,6,1");delay(500);} //toggle relay6
if (keycode==5723199) {Serial1.print("RELAY-KEY-255,7,1");delay(500);} //toggle relay7
if (keycode==5723376) {Serial1.print("RELAY-KEY-255,8,1");delay(500);} //toggle relay8
if (keycode==5723331) {Serial1.print("RELAY-KEY-255,9,1");delay(500);} //toggle relay9
if (keycode==5723151) {Serial1.print("RELAY-KEY-255,10,1");delay(500);} //toggle relay10
if (keycode==5723388) {Serial1.print("RELAY-KEY-255,11,1");delay(500);} //toggle relay11
if (keycode==5723379) {Serial1.print("RELAY-KEY-255,12,1");delay(500);} //toggle relay12
if (keycode==5723391) {Serial1.print("RELAY-KEY-255,13,1");delay(500);} //toggle relay13
if (keycode==5723328) {Serial1.print("RELAY-KEY-255,14,1");delay(500);} //toggle relay14
if (keycode==5723187) {Serial1.print("RELAY-KEY-255,15,1");delay(500);} //toggle relay15
if (keycode==5723136) {Serial1.print("RELAY-KEY-255,16,1");delay(500);} //toggle relay16
mySwitch.resetAvailable();
if (IrReceiver.decode()) {
// Print a short summary of received data
IrReceiver.printIRResultShort(&Serial);
if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
// We have an unknown protocol here, print more info
IrReceiver.printIRResultRawFormatted(&Serial, true);
Serial.println();
delay(0);
IrReceiver.resume(); // Enable receiving of the next value
if (IrReceiver.decodedIRData.command == 0x15) Serial1.print("RELAY-SET-255,1,1"); //turn ON relay1
if (IrReceiver.decodedIRData.command == 0x16) Serial1.print("RELAY-SET-255,1,0"); //turn OFF relay1
if (IrReceiver.decodedIRData.command == 0x17) Serial1.print("RELAY-SET-255,2,1"); //turn ON relay2
if (IrReceiver.decodedIRData.command == 0x19) Serial1.print("RELAY-SET-255,2,0"); //turn OFF relay2
if (IrReceiver.decodedIRData.command == 0x1A) Serial1.print("RELAY-SET-255,3,1"); //turn ON relay3
if (IrReceiver.decodedIRData.command == 0x1B) Serial1.print("RELAY-SET-255,3,0"); //turn OFF relay3
if (IrReceiver.decodedIRData.command == 0x1D) Serial1.print("RELAY-SET-255,4,1"); //turn ON relay4
if (IrReceiver.decodedIRData.command == 0x1E) Serial1.print("RELAY-SET-255,4,0"); //turn OFF relay4
if (IrReceiver.decodedIRData.command == 0x1F) Serial1.print("RELAY-SET-255,5,1"); //turn ON relay5
if (IrReceiver.decodedIRData.command == 0x41) Serial1.print("RELAY-SET-255,5,0"); //turn OFF relay5
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,6,1"); //turn OFF relay6
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,6,0"); //turn OFF relay6
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,7,1"); //turn OFF relay7
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,7,0"); //turn OFF relay7
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,8,1"); //turn OFF relay8
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,8,0"); //turn OFF relay8
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,9,1"); //turn OFF relay9
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,9,0"); //turn OFF relay9
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,10,1"); //turn OFF relay10
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,10,0"); //turn OFF relay10
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,11,1"); //turn OFF relay11
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,11,0"); //turn OFF relay11
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,12,1"); //turn OFF relay12
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,12,0"); //turn OFF relay12
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,13,1"); //turn OFF relay13
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,13,0"); //turn OFF relay13
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,14,1"); //turn OFF relay14
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,14,0"); //turn OFF relay14
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,15,1"); //turn OFF relay15
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,15,0"); //turn OFF relay15
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,16,1"); //turn OFF relay16
if (IrReceiver.decodedIRData.command == 0x42) Serial1.print("RELAY-SET-255,16,0"); //turn OFF relay16
sensors.requestTemperatures();
float temperatureC = sensors.getTempCByIndex(0);
Serial.print(temperatureC);
Serial.println("ºC");
delay(5000);
i think you not use delay(5000) function, just use a timer for variable, whenever the variable has a certain difference value, then output DS18B20 temperature value. if use delay() function will let whole system delay.
I tried flash esp32 via USB C cable. I want start use RF decooding, i do every steps form https://www.kincony.com/forum/showthread.php?tid=1797, lesson 11.
I verify file before flashing, was OK, i Flash untill 100%, restart and now ESP32 in my kc-868 server keeps rebooting. Propably i need clear, new file to flash ESP32??
because you have not upload full file. you can download these file in different addrss, see this photo.
your BIN file at     0x20000
bootloader.bin      0x1000
partion-table.bin   0x8000
here are  bootloader.bin  partion-table.bin  just download zip file, unzip it.
.zip   bootloader.zip (Size: 15.42 KB / Downloads: 742)
.zip   partition-table.zip (Size: 271 bytes / Downloads: 728)
your BIN file at    0x20000 ??
How to create my BIN file?
Does it come with .zip? KC868-Server-wireless-decode.zip
any user bin download at 0x20000
your BIN also download at 0x20000
