A24 configure yaml for ESPhome
#21
hi! there is any reason to use inverted= true in the config? this is to use with NC contactor?
im asking because in the power distribution box diagram you use a NO contactor and i already ourchase like 32 units... thanks a lot!
Reverse the logic of all outputs
thanks.. the yaml send this error when I try to install the yaml file
INFO ESPHome 2026.3.3
INFO Reading configuration /config/esphome/a24-1.yaml...
Failed config
esphome: [source /config/esphome/a24-1.yaml:2]
Please remove the `platform` key from the [esphome] block and use the correct platform component. This style of configuration has now been removed.
platform: ESP32
board: esp32dev
because now esphome yaml syntax is updated. just do as esphome tip.
any oficial new yaml? pi
this is updated, it can directly to use.
  friendly_name: a16
esp32:
  board: esp32dev
  framework:
    type: arduino
# Example configuration entry
   - id: bus_a
     sda: 16
     scl: 5
     frequency: 400kHz
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk:
    pin: GPIO17
    mode: CLK_OUT
  phy_addr: 0
pcf8574:
  - id: 'pcf8574_hub_out_1'  # for output channel 1-12 CS1-CS3
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 13-24
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for a24--input channel 17-32
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
# Individual inputs
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
  - platform: adc
    pin: 35
    name: "A24 A1 Voltage"
    update_interval: 10s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 34
    name: "A24 A2 Voltage"
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 39
    name: "A24 A3 Current"
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 36
    name: "A24 A4 Current"
    attenuation: 11db
    filters:
  - platform: max31855
    name: "K-Type Thermocouple-1"
    cs_pin:
      number: 13
      mode: OUTPUT
      inverted: false
    update_interval: 5s
    name: "K-Type Thermocouple-2"
    cs_pin:
      number: 14
      mode: OUTPUT
      inverted: false
    update_interval: 5s
    name: "K-Type Thermocouple-3"
    cs_pin:
      number: 15
      mode: OUTPUT
      inverted: false
    update_interval: 5s
spi:
  - id: spi_bus0
    clk_pin: 14
    miso_pin: 12
gp8403:
  voltage: 10V
output:
  - platform: gp8403
    gp8403_id: my_gp8403
    channel: 0
  - platform: gp8403
    channel: 1
light:
  - platform: monochromatic
    output: gp8403_output_1
    output: gp8403_output_2
web_server:
  port: 80
yaml file download:
.txt   A24-ESPHome_20260412.txt (Size: 10.2 KB / Downloads: 247)
thanks!!! amazing support like always!
you are welcome.
hi any idea why the thermocouple show a really low level of temperature?
any way to calibrate?
do you use by ESPHome?
can you take a photo , how you wire your sensor.
