Threads: 2
I managed to find the issue. It was the usb cable that the device was delivered with. After I switched with one of my cables it worked as in the instructions.
Threads: 2
Is there an easy way to update the firmware without loosing the existing config? What type of battery can be used for RTC clock?
Thanks
Threads: 2
Thanks for the reply. The new feature is great and congrats for adding that.
At the moment I have v3.18.0 firmware version and from this version to the latest i suspect I have to reflash the board right. This means I will loose all the configs.. Is that right?
Thanks
Threads: 1,385
yes, begin v3.22.0 you can export config file, so after v3.22.0 firmware all will be support BACKUP function. now you update to v3.22.0, re config it , in future never config again.
