Threads: 0
05-10-2026, 05:45 PM
(This post was last modified: 05-10-2026, 05:51 PM by pvana.)
Hi, should I wait for any idea for a solution? No power value in W is displayed in Energy Monitor 2. The mains voltage is displayed. The current is displayed.
The power factor is calculated internally separately for each measuring coil ?
Thanks Pavel
Threads: 1,529
your photo CH3,CH4,CH5 all have data.
do you means CHIP4,CHIP5,CHIP6? you are using N30, so only chip1,chip2,chip3 have data. every chip manager 10 channel CT.
Threads: 0
Hi, I need your opinion on whether I received an N30 with defective BL0910s. Or am I doing something wrong? Alternatively, do you have any ARM CPU firmware I should try? I’ve tried just about everything, and it seems to me that the device is behaving erratically. For example, right now at 1.035 A, it shows 21.8 W at 235 V, while another meter shows 221.2 W.
Threads: 1,529
take a photo screen of your "SysParamModify" page of PC software. i want to see what "coefficient" you are setting. We strongly recommend using Kincony's CT sensor. If using a third-party CT sensor, it requires accurate manual configuration of various parameters, which is quite complex.
