Threads: 1,497
format problem. you are using ‘output-1’, it should be 'output-1'
that is different character.
Threads: 1
Hello sir, i have integrate E16s relay module with KC868-Server - but - manual control button on E16s module is not working
i have attached a screenshot - see output is "on" but when i am trying to manually make it "off" with control button on E16s module it not working
please share a code
Image(s)
Thanks & Regards,
Arshad Abbas
Threads: 1,497
it's normal, work well, because you have not set the INPUT trigger OUTPUT command.
such as these code:
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
on_press:
then:
- switch.toggle: light1
pcf8574: pcf8574_hub_in_1
mode: INPUT
the important is add these code:
on_press:
then:
Threads: 0
i just bought the server , AIO and couple of AP .
How do you recommed to start and configure them? by MQTT or ESP Home?
Threads: 1,497
suggest config by ESPHome, it's easy and stable.
