ESP32 RF
#31
I downloaded 2 files from this topic: bootloader.zip and partition-table.zip. Where can I find the third file? how to create it?
Uploading only 2 files didn't stop rebooting.
Should I find another factory file from the esp32 manufacturer on the Internet?
third is your own BIN file, it's user BIN. you compiled by arduino IDE. Do you understand?
Ok, I created a third file on the Arduino IDE, detected and changed the 6 keycode 433 in my file, exported the compatible binary in the Arduino IDE, flashed the 3 files to esp32 on the server using espressif flash_download_tool. ESP32 does not restart - it's OK. But pressing buttons on the remote doesn't toggling the light.
Is my code in the file written correctly:
.txt   Przełączanie 1-6 znane kody - Kopia.txt (Size: 1.88 KB / Downloads: 611)
if you use arduino IDE download to ESP32 , this code whether work well?
What does the code work fine? When I have the Arduino IDE running, then using the Serial Monitor function, I see that the esp32 in Kincony Server detects pressing the RF 433 remote control. But it does not affect the on / off light / relay.
do you have replaced keycode? every remote have different keycode.
if you can see keycode output value in arduino IDE Serial Monitor, just replace control relay ON/OFF code. if you can't see the keycode when you pressed 433M remote, that's have another problem.
Yes, i replaced keycode. I see keycode on IDE Serial Monitor when i pressed 433M remote, but relay didn't toggle.
(01-11-2023, 01:59 AM)admin Wrote: i have tested code, sorry for my before error photo.
just set serial1 pin define as these will be work fine. here is photo.
#ifndef RX1
#define RX1 16
#endif
#ifndef TX1
#define TX1 17
#endif
if you want to eraser all esp32 data, you can use ESP Tool: https://www.kincony.com/esp-module-flash...tools.html
see this photo, config the serial port in arduino config file. will be work fine.
[Image: attachment.php?aid=1755]
I set this RX 1 and TX1, make new .BIN file in Arduino IDE, flash 3 file and now don't detect keycode ind serial monitor and switch don't toggle.
first step, you need let serial monitor can output keycode when remote button pressed. this step never work?
