02-27-2025, 05:46 AM
Kc868-M16-v2.1
KC868-M16v2 configure yaml for ESPhome
Kc868-M16-v2.1
02-27-2025, 08:05 AM
when we have free time, have a test.
02-27-2025, 08:57 AM
Ok, I'm waiting for your decision, thank you.
02-27-2025, 11:52 PM
you can try to test this code.
Code: esphome:
m16_external_component.txt (Size: 8.83 KB / Downloads: 478)
02-28-2025, 05:01 AM
Thank you very much, it works, tell me how else can I adjust the voltage value, there is an error of about 10 volts
02-28-2025, 06:23 AM
add this "sensitivity" to sensor code. set to 500.00 re compile , have a test.
sensitivity: 500.0
02-28-2025, 06:42 AM
Added as you wrote now with voltage of 218 volts the values jump within 198-225 volts not stable
02-28-2025, 11:14 AM
you can change the parameter. how to calibrate the voltage, see this link: https://www.kincony.com/forum/showthread.php?tid=3764
just use arduino program to find the "sensitivit" value, then replace in esphome yaml file.
02-28-2025, 12:38 PM
Got it, thank you very much
03-14-2025, 01:41 PM
Hello everyone, I need to configure a KC868 M16 V2 card on home assistant. Who could help me? I'm new to the esphome world. I tried with the guides but I can't.
Thank you |
« Next Oldest | Next Newest »
| 1 Guest(s) |
