KinCony ESP32-S3 Core Board ESPHome yaml for home assistant
#31
please use espressif "esp download tool" for test.
download link: https://www.kincony.com/wp-content/uploa..._3.9.2.zip
(02-28-2025, 12:14 AM)admin Wrote: please use espressif "esp download tool" for test.
I tried that before, same result. tried it today and see picture for result
it looks that the SHA-256 comparison is failing
it showed finished. it work well.
its not working, see the serial log after rebooting. after rebooting, and attaching a network cable, it never comes up, even i don't see it apearing in my router
even when i powered the unit, the green led on the ethernet port is on, and when i attach a network cable to it, its goiing off. then the orange one is blinking, but nothing happens
i received another kincony board yesterday, flashed it, and it works directly.
but hat one has a LAN8720 ethernet module while this one has a W5500
take a whole progress video send to whatsapp number: +86-15381188302 we check.
(03-01-2025, 11:32 AM)admin Wrote: take a whole progress video send to whatsapp number: +86-15381188302  we check.
a video of which process?
with flashing there is nothing wrong, only after flashing, the unit is not coming up, and serial log is attached to previous post
(02-21-2025, 11:14 AM)admin Wrote: 1: hold on the DW (download ) button.
2: power on for your KinCony S3 board.
3: remove your finger
then board will enter bootloader, you can download now.
(02-23-2025, 08:44 AM)admin Wrote:
(02-23-2025, 07:50 AM)AshS Wrote:
(02-23-2025, 12:18 AM)admin Wrote: 1. S3 board MUST work with power supply, can you change to DC12V? can't only work with USB-C cable. the USB not power for the PCB.
2. do you have hold on the S2 button on the photo?
right step is:
1. power off S3 board.
2. hold on S2 button (not release your finger)
3. power on S3 board.
4. release your finger.
5. connect USB-C cable to your computer.
[Image: S3-schematic.jpg]
Yes, I am using the correct button.
I have many similar devices. The boards are faulty.
The spec says 9-24V not 12V specifically. 9-24V See screenshot.
my means , you can test with DC12v power . if you have tried different usb-c cable also can't work.
tell us your order number, where you buy from, we will check then feedback to you. maybe need replace ESP32-S chip.
My replacement board have arrived.
I'm sorry to say that I can't connect to these either.
I have checked the voltages at R6 and R4 and also the S1 and S2 switches and all seem to be OK as per the schematic.
This is really frustrating. I am flash ESP32 dev board every day without issue.
What else can we check to get some firmware onto your boards. They are just not going into DFU mode.
do you have a BIN file want to download to S3 board, if YES, you can post at here, i can have a test. your board we have tested then re send to you. i don't know why you can't download by USB-C.
This is my Bin file generated by esphome and flashed with esphome flasher and download tool.
compiled with esphome 2025.2
a minimal setup, only modbus is activated and a binairy sensor for the status
not able to upload a bin file, so compressed it to a zip file
Yaml:
  friendly_name: Kincony_dev
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
  encryption:
    key: ""
ota:
  - platform: esphome
    password: ""
  type: W5500
  clk_pin: GPIO43
  mosi_pin: GPIO44
  miso_pin: GPIO42
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
uart:
  - id: uart_485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 16
    rx_pin: 15
    parity: EVEN
    rx_buffer_size: 1024
    stop_bits: 1
modbus:
  uart_id: uart_485
  send_wait_time: 1000ms
#  flow_control_pin: GPIO4
web_server:
  port: 80
  - platform: status
.zip   kincony-dev.ota.zip (Size: 355.79 KB / Downloads: 472)
right step is:
(03-08-2025, 04:06 AM)admin Wrote: do you have a BIN file want to download to S3 board, if YES, you can post at here, i can have a test. your board we have tested then re send to you. i don't know why you can't download by USB-C.
There's no point in testing my bin file.
I still cannot get any of the four boards to connect to even try a bin file.
I upload to ESP32s every day without issue.
I have tried 3 different USB-C cables (all of which work with ESP32) and they do not work with your board.
I have tried every combination and sequence of power up, S1 press, S2 press, USB C connection sequence and nothing gets the boards connected.
