KC868-M16v2 configure yaml for ESPhome
#61
i use esphome compiled this BIN file, it use by ethernet, you can download to ESP32, test whether work well.
.zip   m16v2.factory.zip (Size: 482.58 KB / Downloads: 607)
I tried but it didn't work...what is the associated yaml file?
it still seems that the card can't connect to the network
do you MUST want to use ethernet?
when you bought M16v2 from? tell us your order number, we will check.
I would like to use ethernet, I bought the card with poe module on purpose. I bought it on 26-01-2025, with Express checkout.
the email is athxp(@)tiscali(dot) it
send your order number and store link to whatsapp number: +86-15381188302 we check for you.
do you have a telegram contact?
now I'm using the card with wifi, I haven't found a way via cable. I think the rj45 module is faulty...
telegram: +86-15381188302
I contacted via telegram but I had no response....is the contact active?
because the same question you send to whatsapp and telegram repeatly. by one chat way is enough.
Hi, I have just bought the KC868-M16-V2.1 and I'm having the same issue display is working with temp and humidity reading but I have no Ethernet working.
I have tried the m16v2.factory.zip and the yaml example supplied in this thread with no luck.
If i use the yaml example for the KC868-M16 the Ethernet works fine but I have no display, temp or humidity
I had the same issue with no Ethernet but I was able to resolve it by using esptool to erase and flash the m16v2.factory.bin
esptool -p /dev/ttyUSB0 erase_flash
esptool --chip esp32 -p /dev/ttyUSB0 -b 115200 write_flash 0x0 m16v2.factory.bin
Now Ethenet works and so does the display.
